Twin Beds in a 2021 320 CS-S?
Aray
Member Posts: 16
Thinking of buying a 2021 320 CS-S but would need twin beds. Since we can't actually see one (since everyone seems to be sold out) we were hoping someone could measure their seating area lengths and report here. Are they both the same length? Are they long enough for a twin bed set up? Any help GREATLY appreciated!
The CSS sleeps wheel to wheel and the bed width is the same as the bench length - 58”. If you set up 2 twins and sleep rear to front, the driver side max bed length will be limited to 58”. You can add an removable extension on the passenger side twin to make it longer.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
Here are some ideas.https://tab-rv.vanillacommunity.com/discussion/11434/2021-320s-mod-stool-with-bed-extension
Many thanks for that, @Sharon_is_SAM. Very helpful. I really though it is was longer. Looks like I may have to rethink things.Sharon_is_SAM said:The CSS sleeps wheel to wheel and the bed width is the same as the bench length - 58”. If you set up 2 twins and sleep rear to front, the driver side max bed length will be limited to 58”. You can add an removable extension on the passenger side twin to make it longer.
For 2 people, the S model is better for a twin bed setup. Since you sleep back to front, it is at least wider and both beds would be 72” long. Also, if necessary, you can add an extension on the passenger side bed. Good luck!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio2
Thanks a bunch, @Sharon_is_SAM! Just what I needed to know..
