Twin Beds in a 2021 320 CS-S?
Aray
Aray Member Posts: 16
Thinking of buying a 2021 320 CS-S but would need twin beds. Since we can't actually see one (since everyone seems to be sold out) we were hoping someone could measure their seating area lengths and  report here. Are they both the same length? Are they long enough for a twin bed set up? Any help GREATLY appreciated!
    The CSS sleeps wheel to wheel and the bed width is the same as the bench length -  58”.  If you set up 2 twins and sleep rear to front, the driver side max bed length will be limited to 58”.  You can add an removable extension on the passenger side twin to make it longer.
  • Aray
    Many thanks for that, @Sharon_is_SAM. Very helpful. I really though it is was longer. Looks like I may have to rethink things.
    For 2 people, the S model is better for a twin bed setup.  Since you sleep back to front, it is at least wider and both beds would be 72” long.  Also, if necessary, you can add an extension on the passenger side bed.  Good luck!
  • Aray
    Thanks a bunch, @Sharon_is_SAM! Just what I needed to know..
