@hobie I’ve used a lockable coupler pin for years, but I’ve recently gone away from that, instead using the spring clip used to hold on the jack wheel. When I remove the jack wheel for towing, that spring clip then is used as my coupler pin. If I was ever away/out of sight from my vehicle while towing for period of time, I would probably go with a lockable pin. Those occasions are rare though, so a spring clip is good enough for most occasions.Hobie said:Is it safer to use a coupler pin lock when towing, or a spring clip? I read about some of the locks falling apart after a time.
