I haven't put any water in the freshwater tank yet, but it's appears to be 2/3 full. Maybe the dealer did that to test the water system. However, when I turn on both pump switches inside and out, I'm getting no water. Not even the sound of the pump. Am I missing something?
0 ·
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
Are you certain you have the Nautilus valves correctly positioned for "Dry Camping"?
The pump can be turned on or off from either the switch located at the Nautilus panel, or at the control center by the front door...as @Denny16 suggested, it works like a 3-way light switch in a house - and can be turned on or off at either location.
When the pump is on, the red led will illuminate at the control panel by the front door (even if you turned the pump on at the Nautilus panel), and the Nautilus panel rocker switch will glow red (even if turned on at the front door panel).
