Hi all:
I've been thinking about using only 15 amp service this fall on our trip to VT, NH, ME, and Prince Edward and Nova Scotia, Canada since we probably will not need the AC. I usually use a hot pot to heat water for dishes and coffee or a small electric skillet for breakfast - but not at the same time since they are both rated for ~12 amps.
So I'm thinking about using a 12 gauge 25' extension cord instead of the 30 amp cord for convenience purposes and ease of handling. I will not use the hot pot or skillet at the same time due to their amp draws.
So should I just plug into the 15 amp outlet in the pedestal without a surge protector, or, plug my 30 amp surge protector into the 30 amp outlet and then use my 30 to 15 amp adapter to plug the extension cord into in order to have surge protection? There are 15 amp circuit breakers in the T@B.
Please let me know of potential electrical downfalls you might see with this kind of set-up.
John
2018 Chevy Colorado V-6
Edmond, OK
Edmond, OK
Edmond, OK
But I tend to agree with all those that are saying, 'why bother?'.
That 30A cord (that came with our Tab) is surprisingly flexible and easy to coil, even when cold.
We usually extend that 30A cord with a #12 also.
the 30 amps cord are a bit overkill for our little trailer usage, but they went with safety in mind and the campground standard of 30 amos for peace of mind and cover for abuse by ignorant or carless users that would choose to bring house 1500 watts heater to heat up pup-ups and other stuff like that.
i run the ac with a standard 110 utiliy extension (but in good shape) at the end on my 30 amps cord from my house 110 15 amps breaker outlet and the cable does not get hot.
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
Edmond, OK
so the only big power draw is the small ac or a small space heater.
2017 T@B 320 Max S
2014 Ford Escape 2.0 EcoBoost
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
