I have a 2016 T@B 320 CS-S and tow it with a Ford F-150. When dry camping is there a way to store a water tank in the bed of the truck that has a water pump hooked to the tank and feed the water into the CITY WATER connection? Let's say the water tank held a minimum of 50 gallons? I want a way to supplement the fresh water tank and the water supply in general when dry camping. Weight from the extra water will not be an issue for towing purposes. Thoughts?
                0 ·
It could be alleviated by unhooking and then going to fill the bladder.
Or, just trade up to a 2021 T@b that has an 18 gallon water tank. 😁
cheere
I can make an 18 gallon freshwater tank last a week, with zero effort at conservation and lived for 3 months with a 5 gallon freshwater tank, refilling with a spare freshwater tank 1-2 times a week.
https://www.amazon.com/dp/B0863WL6FG
... has a 85psi automatic cutoff and could be used with a 40psi regulator on the hose to go into the city water supply. But I'd find a better one... this is just an example that there's plenty of pressure regulating water pumps, some at 35psi, some 85psi, some 100psi. Most are self-priming.
Even a 45psi 3.5gpm Shureflo like the default T@B water pump could work? Though if you have updated your shower head to a 1.5gpm like the awesome Niagara Conservation head, the above that rate may be overkill.
https://www.walmart.com/ip/Shurflo-2088-554-144-Fresh-Water-Pump-12-Volts-3-5-Gallons-Per-Minute-45-Psi/538069243?wmlspartner=wlpa&selectedSellerId=8755
