Hi there all you wise and knowing T@Bber’s.Has anyone out there found a way to use an impact driver to help raise and lower the stabilizers on a 2020 T@B 320 BD. I have a healing torn rotator cuff and this up and down with the one metal handle is taking a toll on my recovery. I can’t find anything that works on that metal bolt with the two small teeth that is on the trailer. I can get socket that is close but it spins a bit and I don’t want to wear those little “teeth” down. I thought NuCamp might have an adapter but no luck going through my dealer. Any work well for you?
Kr@cken
2020 T@B 320 Boondock
2020 Subaru Ascent
Bainbridge Island, Wa
0 ·
Ultra-Fab Products 48-979071 Ultra T-Slot Drill Attachment for Scissor Jack https://www.amazon.com/dp/B00Q6ISG4M/ref=cm_sw_r_cp_api_i_eT7sFbWJSHVCH
2020 Subaru Ascent
2020 Subaru Ascent
2020 Subaru Ascent
2020 Subaru Ascent
I was thinking more of impact wrenches and hammer drills--different (and more aggressive) tools that will probably rip or knock your stabilizers clean off!
Too many similar looking tools with similar names for me to keep straight! :-)
2018 320 S - "No Agenda Hacienda"
Tow Vehicle 2023 Honda Pilot AWD
2020 Subaru Ascent
Odessa, Fl.
(I changed the title for you - Sharon.)
2020 Subaru Ascent
Additionally I put a "swivel" adapter on my extension (a semi universal joint). It allows the socket just a little wobble. It's easier to control than a full universal joint.
Like this:
There's one designed for your drill driver here at Home Despot:
https://www.homedepot.com/p/Makita-Impact-GOLD-3-8-in-15-Degree-Tilt-Socket-Adapter-B-35075/203696899
2020 Subaru Ascent
with your favorite battery drill.
Odessa, Fl.
