I have a 2018 Outback edition TAB. My problem is that the Alde control panel (3010-614) is completely blank. I was using the Alde this Spring and the power just shut off to the panel. (I was not in the RV when this happened so I don't know how it reacted when it shut down).
Question 1- is there a way to test the control panel to see if its receiving power? I've tried the normal problems, changing the fuses, check plug, check all wirings etc....but nothing seems to work.
Question-2 I don't want to purchase another unit until I know that it is toast! Has any other TAB owners have/had this problem. How was it solved?
Thanks for you input.
PS: I have sent Alde two recent emails to their service department but as of today no response from them.
0 ·
This is from the June 12 post regarding troubleshooting the Alde Control Panel:
“We found another members experience with the Alde Control Panel failure. He checked with Spencer from Alde US. A way to check the control panel is to “unplug the white DC power plug (between the two green fuses), then watch the control panel screen as you plug it back in. If the screen briefly flashes from black to white, the screen is getting power, but the board in the panel is bad. So, we tried this and the screen flashed black to white, so apparently the control panel board is shot. But, does that explain the blown Alde fuse or the 10 amp fuse?“
FYI: as it turned out, our control panel was fine. We had a short in our fan that was on the same circuit as the Alde.
But, as Verna suggested, start by turning off all power, disconnecting the Alde 12 v line between the 2 green fuses. Wait a bit as I think the control panel “resets”, then return the 12 v line (wait a while in case the resetting occurs at this time) and power up.
PS: Travels with Delaney recommends pulling the Alde 12 v cable FIRST then replacing the Alde fuse(s) then reinserting the cable.
Thanks, Jerry
I'm off to Yellowstone for a week so I will look into this further upon my return!
Thanks, Jerry
BrianZ provided a good picture Of the Alde 12 v line in the link below. It is between the 2 green fuse holders.
Anyway, I emailed Nucamp tech support but still haven't heard from them yet. Will wait to see what they say tomorrow, I hope.
Also, take a look at the info provided at the below link for a possible source of the problem:
https://www.motorhomefun.co.uk/forum/threads/alde-3010-blank-control-panel-solution-fix.154521/
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
