Inadequate Lighting
scaup
Member Posts: 82
We have a 2016 320.
I've always thought the interior lighting was inadequate. To me the one light in the ceiling was too far forward for adequate lighting while sitting at the table. I've tried a couple of stick-on battery powered light over the table but they didn't seem to help. Maybe I just bought bought the wrong ones.
Has anyone tried removing the fan to gain access to the space between the ceiling and the roof to install new 12 vdc recessed lights, similar to the one ceiling light, on either side of the fan? Or has anyone found a bright stick-on light.
Thanks
You only have about 1.5-inches of space in ceiling area p, which is filled with foam between the roof and inside ceiling panels. Their are a lot of new LED camping lights that could be hung from a bracket attached to the ceiling (use a stud finder to locate the aluminum frames in the ceiling). Many have their own batteries and do not require wiring. Goal Zero has a nice small, but bright hanging light, that need to be plugged into a 12VDC source.
Have you tried the Lucci solar lights? They give off plenty of light.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
We really like this setup. Picked up power source from the fan. If I remember it comes in soft white or bright
Heng's HG-LR-W-WW-AFT LED Vent Trim Kit, White Lens Ring Diffuser - Warm White Light
Demco
$33.50- Hash T@B Fun
Oh dang it... now this forum is forcing me to buy another tweak for the T@B.
Former steward of a 2017 T@B S Max3 -
@DougH, but your hands up and your credit card away! Resist!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
@Sharon_is_SAM ; Too late... ordered. Sigh. But brilliant find @Marceline and @Dalehelman. Thanks.
And thanks @scaup for bringing up something that always kind of bugged me, but I couldn't quite identify it. I had those solar Luci string lights to hang on the shelves, but it wasn't always enough.2021 Jeep Gladiator, 2021 tiny toy hauler, Austin TX
Gee thanks, @Marceline and @Dalehelman! It’s in my cart on Amazon....Verna, Columbus, IN
Glad to hear that it actually works. I probably should've installed it when I had the fan taken apart to install the PWM.Dalehelman said:We really like this setup. Picked up power source from the fan. If I remember it comes in soft white or bright
Demco
$33.50San Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
I installed a light similar to one of these along the back edge of the fan frame. It is nearly the same thickness as the frame and easily connects to the fan power line. Plenty of light over the table and touch switch dimmable.
https://www.ebay.com/itm/RV-Interior-LED-Strip-Ceiling-Lights-Kitchen-Sink-Counter-Slim-Line-Light-12V-6/264694104978?var=564501048307&hash=item3da0ff8392:g:VRMAAOSwEIBejZqO
We have a solar powered Luci light from tent camping and simply hang that from the fan's open/close handle.Tteam, Wisconsin
2020 TAB 320S Boondock Lite
TV: 2018 Jeep Grand Cherokee3 -
That is a good solution and the new ones even include some super bright clear units, that are smaller than the original Luci lights.
@scaup @Verna Got the warm light variant delivered today. What it looks like and a before and after shot. Love it.
Instructions said to replace the white fan surround. That showed some gaps between the wood and fan since the LED surround is clear plastic. So I put it on top the existing surround. Instructions said drill a hole for the new threaded pushbutton switch. But my package didn't come with the nut to tighten it in place; I just VHB'ed it.
What back corner looks like without the new LED surround on...
And what it looks like with it on...
Former steward of a 2017 T@B S Max4
