I did my first sanitizing procedure this weekend. For 2 reasons I wondered how long the pump would run. 1) Dry Camping to refill the Fresh water tank (2021 pump method) 2) Filling the Gray Tank w/ the (former) used bleach solution (even a partial but significant fill). I figured the pump would overheat if run too long and shut down. It did, I didn't time it but it ran longer than I would use except for a long shower. So from a practical standpoint it was fine. But if I was refilling our fresh water tank with 10 gallons (for example) I do not believe it would do it even with a break while I refilled the 5 gallon water container. What am I missing? This poor pump may need some help if this is done a lot.
managed by VE Smart Network
0 ·
After this, set the Nautilus back to dry camp, and run water through the fixtures, let it sit for whatever sanitizing period you prefer, and then dump to ground.
Before I did more tests (which I will now do) I wondered if our astute forum members had done any continuous pumping with this "wonderful" SureFlow pump
If pumping approx 5 gallons shut the pump down, there is definitely something wrong with the pump - or there is some obstruction as you mention.
That is not normal behavior.
I carry a spare filter and filter housing...as those seem to be needed on these systems periodically.
https://www.amazon.com/gp/product/B083BKXJM1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
