Hello, All. My wife, Sara and I (John) are on our maiden voyage in our brand new T@B 320S Boondock pulled by our Toyota Highlander Limited. We traveled from Little Rock, Arkansas to Houston, Texas to see our children and grandchildren. We have not seen them since February and that was the inspiration to get the T@B. We wanted to be safe and self-contained. Everything has really gone well, but we have already had a few near-mistakes. We will return to Little Rock this weekend after a couple more nights camping and I'll give a full update. But, there are a few things I've learned so far:
1-Put the step in before hitting the road.
2-Never arrive on the first night of your maiden voyage after dark.
3-Put the step in before hitting the road.
4-Leave yourself plenty of room between you and the car in front of you. Even with the electric brake kit, it is different when having to brake suddenly.
5-Put the step in before hitting the road.
6-Lock the generator to the rig even if you are in the vehicle. More on that theft-attempt later.
7-Smile and be friendly to every motorist who drives by pointing at your trailer yelling, "YOUR STEP IS OUT!"
                15 ·
I bet you won't forget to put the step back, again.
Welcome and congrats!
Tampa FL
They said they could take deposits for campers being delivered spring of 2021.
Tampa FL
All 4 of my kids were born in Tampa, so I guess they are 1st generation natives.
Thanks for the info on the park. Between Covid, the rain and the oppressive heat we only camped once this year so far, back in February.
A friend had recommended Oleta River State Park, but that is even closer to the Miami hot spots.
Tampa FL
Your brake controller LED also tells you when the connection is working or not.
There is a manual lever you can use to test/adjust the trailer brakes. Try it sometime in an empty parking lot.
Let us know the brand/model controller and we can locate instructions for it.
If your trailer ever starts swaying (very unlikely) then you can use the lever of button on the brake controller to activate the trailer brakes (without engaging the vehicle brakes) for a few seconds to help get the trailer back under control and towing straight. Not all controllers may have this feature. Refer to the instructions that came with your controller.
When backing up, that requires a turning maneuver, remember to disconnect the sway bar first. Backing up straight is not an issue with the sway bar. Have a grand trip, and be safe JP.
