Wondering if anyone else has had an issue with their side windows leaking. Ours is on one side. The seam of the rubber window gasket was installed dead center at the top of the window, and water drips down the seam and runs down the inside of the window. Seems like a bad idea to put the seam at the top. It let in enough water this weekend to dampen the side cushion overnight.
Has anyone replaced the gasket before? I'm afraid it will be difficult to line up correctly, and be a mess to work with. Or is there some type of repair material I could add to that area?
I've got it temporarily fixed with duct tape, and while that's a source of pride with my climbing gear, it's not the look I was going for with the T@B.
2022 Ford F350 Tremor | 2022 Cirrus 620
