I have a 2019 T@B 400 with the Alde 3020 and Alde Flow. Last winter when I was preparing for a winter trip, I ran the Alde heating system, which up until then worked fine, for a couple of days to check things, and came home to see gylcol on the pavement, which came out of the automatic airbleeder I believe. Nucamp provided me with a new airbleeder under warranty, but since then I have not been able to get the system to work. After replacing the airbleeder I topped up the gylcol and have bleed the lines, using the bleeder in the bathroom, along with raising and lowering the trailer. And today I parked the trailer on a hill for 3 minutes, opened the bleeder, and did the same sloping down - in all of these cases I have fluid coming out. The glycol is moving up and down in the reservoir, once it overflowed. I am only getting heat the first 2 to 3 feet in the hose towards the bathroom - which leads me to think I have an air lock? Tonight, based on the British Alde manual I also turned the circulation pump up to 5 for ten minutes, and got the same results.
To add more confusion to this, in doing the troubleshooting with Nucamp it was determined that while I have the Alde Flow in my trailer it does not come up as an installed accessory. NuCamp sent me a new controller, but when I plugged it in, the Alde Flow still did not show up. With more troubleshooting, I determined tonight that the wire going to the optional board was not plugged in I am assuming when it was manufactured. However after plugging it in, and setting it back to the default settings it still does not show the Alde Flow.
I don't know if these two issues are related or not. I am also wondering if I have an air lock between the reservoir, which is in the front left corner and the line that runs along the back of the bed and into the Alde Flow. While I have really appreciated the assistance NuCamp has given me via email, I am hesitant to go back to the dealer since we have not been happy with their service. Any suggestions or thoughts on what else I could try would be appreciated, thanks.
0 ·
If you have the red tank, you have made the wire connection, then you must activate it on the Alde control panel:
” ACTIVATING ALDE FLOW
Denny, thanks for the list I will work my way through it.
- As the Alde temp rises, the hoses near the unit heat up, though no more than a few feet
- If I turn the unit off, and open the bleeder valve in the bathroom, only glycol comes out
- At times as the temperature rises, the fluid in the reservoir builds up and will overflow through the bypass onto the pavement, sometimes resulting in the fluid being below the min line, so I add more glycol
- Based on feel, both circulation pumps on the Alde and Flow appear to be working
- Raising the trailer up high and low does not seem to help, and running both pumps at the five levels does not seem to help either.
- Even with the mixing value set to its max, the water is warm, but not hot.
A few questions
- Any other suggestions?
- What is the normal running temperature of Alde glycol? Does it maintain a constant temp or fluctuate?
- I understand that it could also be a kinked line. My thinking is that a kinked line would normally occur during manufacturing. Has anyone experienced a kinked line after the system worked fine?
Thanks for your time
I believe that both the 3010 and 3020 models have a manual glycol pump setting. Have you been trying to adjust the pump circulation via the control panel?
Is your glycol pump in the Therm mode or Continuous?
The water temperature gets up to 150-160 degrees. I imagine the glycol temp is similar.
The glycol and water temperature at the Alde itself can be read in the service mode on the control panel. Normal is around 140f and after boost mode for 30 minutes around 180f
It sounds like the glycol is NOT circulating for some reason?
I have only been running the gas, since I only have 15amp. I am getting gylcol temperatures around 180, and 160.
The valve I am opening in the bathroom is the bleeder valve for the Alde.
Two other questions
- Does anyone know which way the fluid flows - does it go from the Alde to the bathroom, front of the trailer - clockwise?
- While I feel the heat on the Alde, I do not feel any heat from the Alde Flow
Thanks
And on the Alde control unit I have it set to continuous
The bleeder valve is at the end of the circulation, before the connection to the Alde return.
That said, this may take several goes to get all the air out, keep an eye on the reservoir level, adding more fluid as needed. The bleed valve glass container will collect the fluid as it is drained, so you can add it back in after letting it stand for a bit to release any air from it. There is also an auto bleed valve between the Alde and Flo tanks.
I will try your suggestion with the hose tomorrow. Thanks
I know this is frustrating, but that’s all I have. Is the air bleeder in your first picture stuck open causing air to entrain? Just thinking out loud here.
https://tab-rv.vanillacommunity.com/discussion/2665/changing-out-the-alde-fluid/p1
Also, just a thought . . . . . . . you indicated that you raised the pump setting to "5" for about 10 minutes. After that, did you return it back to 1.5 to 2 (normal setting range)? I've never read anything about it, but if you did not return the pump to its prior setting, I wonder if there is too much pressure being created in the line due to the high pump setting.
