Some owners open the drain valve at the dump station and drive off. It empties as you drive. The only other thing is to use your pump and open all your faucets and let it empty into your gray tank, then dump. We have used the shower wand to add water to the black tank and to rinse the black tank at the dump.
If you look inside the filler door (we have a 2020 400 BDL), there is a vented screen below the filler. On the 2021, I am not sure but all others have this. If it weren't vented, the tank would collapse as you draw water out of it.
2020 400 BDL aka "Boonie" 2022 Black Series HQ19 aka "Cricket" 2021 F-250 Tremor with PSD aka "Big Blue" Concord, NC
Yep. One way to find it is to overfill the tank. You'll get squirted from the vent.
Rich
2019 T@b 400 2013 Toyota Highlander 3.5L V6 2025 Toyota Highlander 2.4L Turbo
We're in the midst of learning to calibrate tank filling with needs. Two nights out equals 15 gallons (or whatever we arrive at). Hose fill rate at ___ gallons per 30 seconds, that sort of thing.
Bottled water is already more expensive than gasoline. In high desert we collect cooler shower water (for gardening) before it's ready to step in. Just can't bring ourselves to let tank water dribble out on a road. It is a little bit of a pain to fit a 3 gallon bucket under the valve, collect water, empty and repeat. Hopefully we'll get it calibrated soon!
2020 T@B 400 BDL towed with 2019 Nissan Frontier Pro-4X Tucson, AZ
@johnfconway I agree with you John, why waste water. You could attach a tube to the drain and run that into your garden or a bucket alongside the trailer. When draining our TaB, I park it on the grass field area, and let the water drain out before unhitching. Then move the trailer to the driveway storage area. Draining into a bucket for the veggie garden is an excellent idea. I might try doing something similar. cheers
2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.
St Catharines, ON
Tampa FL
St Catharines, ON
Concord, NC
