I've got a 2021 TAB 400 BD. Saw some folks with water system issues on brand new units that led to floods under the bed. So today we decided to do a simple test - ran the two sinks and the shower, each for just about 10 seconds.
Sure enough, we've got a pretty good leak coming from the blue pipe I circled below. Looks like it's leading from the Alde water pump. Any ideas to take care of the leak? Should I empty the fresh water tank? Leak is very slow but steady. if we hadn't thought to test it out and just went camping, this would have been a PROBLEM.
Can you identify exactly where the water is coming from? The Alde does not have a water pump - only a glycol pump.
I looked around to see if anyone had a picture of a recent Alde drain valve in place, but couldn't find a pic with just a few minutes of searching. Will keep looking.
Do you know if the yellow drain valve is supposed to be up or down. Right now it's down. Wondering if that could be part of the problem too?
Did you try flipping up the valve? Someone recently found that the yellow flapper was not seated completely, but that should not cause an inside leak.
I did find another recent pic from Giota that looked just like yours, so maybe that's how they are and that thinner blue plastic flange is a compression fitting. Not what I'm used to on pex fittings though... they normally look like the ring you have on the right side.
EDIT: If you look for John Guest fittings they have that same look. Thanks for a professional weighing in below.
But regardless could be a bad connection now that you've confirmed Sharon_is_SAM's suspicions and a hose clamp might correct it, or it could be a cracked valve.
And sorry for your trouble.
Also, on occasion, those valves are defective.
Which side of the valve is it leaking?
You have a new trailer, under warranty, I would let the Dealer and nüCamp sort this out for you. Sounds like you have a bad fitting, adding a hose clamp may help, but this seems like a bandaid fix. I have fitted a few PEX fittings and sometimes they develop a leak.
There are two general types of PEX fittings. The most common utilize crimp or clamp compression rings to form a seal between the tubing and fitting. This is what you find in the T@B.
Expansion fittings (which go by the brand name Uponor or ProPex) are designed to be stretched and placed over a fitting. They have a memory so when they return to their normal size they form a tight seal.
Uponor/ProPex systems are different in almost every way. The fittings are different, the PEX is different, and the tool to install it is different. The components are not necessarily interchangeable with the more common compression ring systems.
I'm inherently distrustful of push-on fittings, though many have used them without issue. I used a Shark-Bite fitting to repair a leak in my T@B because there was no way I could have fit a crimping tool in the confined space behind the bathroom wall. So far, so good!
What you should try first is to fix the leak by pushing the tube into the fitting to make sure that it is seated.
If that does not work turn off the water and remove the hose to check if it is cleanly cut. If it's not you can try to fix it by trimming it wit a very sharp knife or ideally with a tubing cutter...the problem will be if there is not enough tubing length to allow that. The cutter needs at least 1/2 inch of spare tube to make a good cut. If you don't have enough hose you should contact nuCamp and ask them to send you some so that you can stop the leak. You should also ask for a new fitting in case that is the issue. These are not sharkbite type fittings, it looks more like Festo style.
