We are getting ready to take the final trip here in October and Colorado high country is getting a bit nippy. We want to use the Alde heat system for the first time and am wondering do we need to fill the fresh water tank to use the heating system? The control panel indicates hot water only can be heated or hot water and heat as the second option. Nothing about heat only. The manual is not really clear. Thanks for the help
2015 Tab S with Alde
0 ·
Concord, NC
If you are going to use LPG and electric and no water: D, F, I and turn the thermostat K
If you are only able to use LPG: A, F, I and turn the thermostat K
If you select "heat and hot water"--but don't have any water in the system--you have effectively selected "heat only." :-)
2015 T@b S. 2017 Nissan Titan
3. ?fresh water connection. You either connect to city water or you use the fresh water tank and pump.
4. Have you filled the Alde tank with water?
Also, there are some fuses inside the Alde itself, that have a tendency to go 'without reason' (and confound the best of us).
Do a search on the forum for Alde "hidden fuses" here: https://www.google.com/search?hl=en&q=site%3Atab-rv.vanillacommunity.com%20Alde%20"hidden%20fuses"
That you are are getting no heat--and hearing nothing--points to a problem with the 12V power supply. Regardless of your heat source, 12V power (from the battery or converter) is always required to run the Alde's brain. As ChanW suggested, I'd start with checking the fuses (including the hidden glass ones on the top of the unit itself).
