It’s best to dump at a fairly full level, but not absolutely mandatory as long as the contents have broken down (use Happy Campers powder for that!) and you’ve been flushing with adequate water. You’ll still need water to rinse either way though. There’s generally a water supply at every dump station; if you can’t or don’t want to run a hose from there into the bathroom to add water via the toilet, you can always use a bucket or collapsible water container to do so manually. Just label the container as non potable as those water sources are not always the cleanest.Kr@cken said:I am so glad someone asked this question. This is a very awkward topic to discuss but I might as well go for it. I solo camp and have not used the black tank since I bought my T@B last fall. I use the RR if one is available and the disposable bags if there isn’t a facility. I remember reading early on that you should be sure to get your black tank to a certain level so that it will empty as designed. I never felt like I was using it enough to to get to that level. I sure would like to be able to stop buying those expensive poo powder bags but don’t carry enough extra water to get the tank 2/3’s full. Is it accurate that the tank needs to be 2/3’s full to ensure proper drainage? Perhaps I got some some misinformation.
It should be fine, assuming a) it really doesn’t freeze, b) you remember to dump and clean out the tank again (keep in mind, you’ll need to get enough water in there via some method to rinse thoroughly!), and c) you remember to work antifreeze back into the gate valve after dumping. Personally? If I were going to take the trailer out now with antifreeze in the pipes, I’d go with the bag & litter method. It’s less work. But it’s certainly doable to just use jugs of water with the toilet.PNWtabber said:New but related question. Using the trailer in the winter after it is winterized. If I am camping in an area with no risk of freezing, but I don't want to completely de-winterize the trailer, can I use a bucket of water to flush the toilet, and then, after draining the holding tank, just add antifreeze back into the toilet? I'm not sure if that is more work or less than just using the bag techniques already discussed. Whoever expected to think so much about these things!!
