This forum has been great. Thanks for sharing your expertise with new users.
I have a 320 Tab Outback, and no bathroom. No digital readouts on this particular T@B.
I've been frustrated whenever I'm trying to make sure that my fresh
water tank is full. I fill slowly, and recently even bought a funnel
and attached a 12" plastic hose for filling from fresh water containers
at campsites. I also have one of the hose shutoff connectors for when
filling from a hose. My problem has been that even when filling slowly
the water begins to backup and overflow at some point. At first I
thought that this indicated that the tank was full, but it has become
evident that it isn't full as the water goes down and then I can fill
some more. Today I spent almost an hour trying to fill the 11 gallon
tank. After reading some forums I finally detached the trailer from the
car, and raised the trailer as high as I could. Even then, though it
worked better, it still took repeated efforts to finally feel that it
was topped off.
I would really like to find a way to know when it is actually full.
And and easier way to fill. At a campground, when topping up the tank,
do I need to raise the stabilizers and then raise and lower the trailer each time i want to add water? Any suggestions would be great. Thank you.
My tank filled much quicker once I got the vent line opened up. However--as you discovered--it still helps to raise the front of the trailer to keep water from backing up into that vent.
If the vent does become filled with water, I clear it by blowing hard into a short piece of tubing held against the vent hole above the filler. That usually gets me back in business for a while.
Once you establish good flow into the tank, it become clear when the tank is full. The water will just gently back up into the filler port and overflow without any sputtering, burping, or other drama
Admittedly, it's not a very well-engineered system. However, once you learn to finesse the venting and control the fill rate it works ok.
https://www.amazon.com/gp/product/B007NHS9M4/ref=as_li_qf_asin_il_tl?ie=UTF8&tag=knowledgeshar-20&creative=9325&linkCode=as2&creativeASIN=B007NHS9M4&linkId=eb188c6effa0de319131f48287398f65
Here's the answer from NuCamp customer service for a 320S:
"while the nautilus does warn against overfilling we have a setup to where it will not damage the tank / lines if you overfill. There is an overfill line outlet that’s located right behind the Nautilus panel itself that will spit out water when the tank is overfilling .... {extraneous text removed}.... I made sure to check with Quality Control on this as well and they say the same thing."
So, no worries!
Bloomington, Indiana
