Generator for Cool Cat
System
Administrator Posts: 188
This discussion was created from comments split from: Our Great Big Tiny Ski Area Tour.
Does anyone use a generator to power their heating units when not connected to shore power? My T@B has a cool cat heat pump and I am trying to decide if a 2000W generator will be sufficient power.
Hfisher, not unless you add a soft start unit. A 2200i Honda seems to be the minimum size required to run the Cool Cat. That said, the Alde runs on LPG and a little DC power, and heats the TaB better. The Cool Cat is only good for heating down to around 40F.
@Hfisher - what model TaB do you have?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
I have personal experience with the 2200i, propane conversion and starting and running the CoolCat at elevation up to 3000 feet. A soft start would be better, but it does work without in my testing.2019 T@B 400 Boondock Lite
Running on propane decreases the number of watts produced by the generator...N7SHG_Ham said:I have personal experience with the 2200i, propane conversion and starting and running the CoolCat at elevation up to 3000 feet. A soft start would be better, but it does work without in my testing.
The 2200i should be sufficient for the Coolcat when run on gasoline, even without a soft-start kit.2025 T@B 400 Boondock Black Canyon with 400Ah Battle Born and Victron Multiplus 3000
2025 Honda Ridgeline Black Edition with Redarc Trailer Brake Controller -
@ChrisFix agree, but I always mention the propane and altitude I have tested to so folks get a little more info. I think the soft start while not needed, would make a smoother start with these 2k class of gensets.2019 T@B 400 Boondock Lite
Yes, yes it would, and would be a worthwhile mod. It also quiets thenCoolCat operation whilst on shore power, giving smooth, quiet starts.Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.
From my CoolCat experience, a small ceramic electric space heater is much more effective and a lot quieter than the CC. I found the heat pump function useless. The generator use for cooling mode would be very nice.
Okay, I am in bewilderment mode here. I have a 2009 Dutchman, with Coolcat A/C and heatpump. I also have a Honda eu2000i generator. I accept that I cannot run the CC on the Honda, I have tried that. So I was looking for options, and dived into the documentation for that model of CC. It says it requires a 2,800 watt generator, so the eu2000i (Honda say 1,600-1,800 running watts is normal) being insufficient is no surprise.Here's where I get confused. 2,800 watts divided by 120 volts says 23.33 Amps. But I know for fact that I routinely run my CC air on a 15 Amp circuit, because that is the outlet in my garage, and I run the A/C off of it.Does anyone know the actual wattage draw for a Coolcat?
The Cool Cat only draws the full 2800 watts on startup. What you can do, is Denny a Soft Start system to the CoolCat AC to reduce the startup draw. The new Honda 2200i will just run the CoolCat.
Also, in my wandering around looking for info, I found the report that converting a Honda eu2000i to propane (I did the Hutch Mountain) will cost you about 10% in efficiency when running on propane. Also, the eu2000i is tuned for 5,000 elevation, and each 1,000' you go up from there will cost you ~3.5%, depending on if you fiddle with jet sizes.
Looked at the softstart option. It brings me back to just replacing the whole thing with a newer 6,000 - 8,000 BTU unit that draws maybe 400 - 700 watts.Buying a complete replacement A/C ends up being cheaper than many of the softstarts. And a simple ceramic heater beats the heatpump. All of which have been discussed on this forum, but I keep going in circles to convince myself.Long ago I told myself that the Dutchman T@bs were a kit, that we all customized. I just thought after a decade I might be getting close to done.
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
