Generator for Cool Cat
    HfisherHfisher Member Posts: 2
    Does anyone use a generator to power their heating units when not connected to shore power?  My T@B has a cool cat heat pump and I am trying to decide if a 2000W generator will be sufficient power.
    edited November 2020
    Hfisher, not unless you add a soft start unit. A 2200i Honda seems to be the minimum size required to run the Cool Cat.  That said, the Alde runs on LPG and a little DC power, and heats the TaB better.  The Cool Cat is only good for heating down to around 40F.
    Sharon_is_SAMSharon_is_SAM Administrator Posts: 9,513
    @Hfisher - what model TaB do you have?
    N7SHG_HamN7SHG_Ham Member Posts: 1,261
    I have personal experience with the 2200i, propane conversion and starting and running the CoolCat at elevation up to 3000 feet. A soft start would be better, but it does work without in my testing.
    ChrisFixChrisFix Member Posts: 725
    Running on propane decreases the number of watts produced by the generator...
    The 2200i should be sufficient for the Coolcat when run on gasoline, even without a soft-start kit.
    @ChrisFix agree, but I always mention the propane and altitude I have tested to so folks get a little more info. I think the soft start while not needed, would make a smoother start with these 2k class of gensets.
    Yes, yes it would, and would be a worthwhile mod.  It also quiets thenCoolCat operation whilst on shore power, giving smooth, quiet starts.
    rfuss928rfuss928 Member Posts: 941
    From my CoolCat experience, a small ceramic electric space heater is much more effective and a lot quieter than the CC.  I found the heat pump function useless.  The generator use for cooling mode would be very nice.
    Okay, I am in bewilderment mode here.  I have a 2009 Dutchman, with Coolcat A/C and heatpump.  I also have a Honda eu2000i generator.  I accept that I cannot run the CC on the Honda, I have tried that.  So I was looking for options, and dived into the documentation for that model of CC.  It says it requires a 2,800 watt generator, so the eu2000i (Honda say 1,600-1,800 running  watts is normal) being insufficient is no surprise.
    Here's where I get confused.  2,800 watts divided by 120 volts says 23.33 Amps.  But I know for fact that I routinely run my CC air on a 15 Amp circuit, because that is the outlet in my garage, and I run the A/C off of it.
    Does anyone know the actual wattage draw for a Coolcat?
    The Cool Cat only draws the full 2800 watts on startup.  What you can do, is Denny a Soft Start system to the CoolCat AC to reduce the startup draw.  The new Honda 2200i will just run the CoolCat.
    Also, in my wandering around looking for info, I found the report that converting a Honda eu2000i to propane (I did the Hutch Mountain) will cost you about 10% in efficiency when running on propane.  Also, the eu2000i is tuned for 5,000 elevation, and each 1,000' you go up from there will cost you ~3.5%, depending on if you fiddle with jet sizes.
    Looked at the softstart option.  It brings me back to just replacing the whole thing with a newer 6,000 - 8,000 BTU unit that draws maybe 400 - 700 watts.
    Buying a complete replacement A/C ends up being cheaper than many of the softstarts.  And a simple ceramic heater beats the heatpump.  All of which have been discussed on this forum, but I keep going in circles to convince myself.
    Long ago I told myself that the Dutchman T@bs were a kit, that we all customized.  I just thought after a decade I might be getting close to done.
