Broken Handle
I need to replace the broken handle. Can someone point me to where I can buy the assembly... preferably Amazon.
Mickey & Terri
2016 Max S
Kalamazoo Michigan
    ScottG Posts: 5,688
    I have the same repair pending but have yet to order the part. I plan to remove the broken handle after I winterize and figure out the thread size. Amazon has several, including metal versions.
    I'll post back here when it's fixed, unless you beat me to it.  ;-)
  • GatorEgg
    GatorEgg Posts: 482
    Just file/finish the broken edge of.  It looks like a weight saving mod.  You shouldn't need the leverage of a two handle, and I never understood why the handle is so big anyway.
    Odessa, Fl.
  • Cbusguy
    Cbusguy Posts: 771
    edited October 2019
    Not sure I would replace it with metal as I would rather the handle break than something less easy to change deeper in the plumbing.
    2009 GMC Canyon,   3.7 liter
    ScottG Posts: 5,688
    Yeah, despite my intentions to make the repair, lazy reality says I'll probably leave it as is since it still works just fine.  :-)
  • VictoriaP
    VictoriaP Posts: 1,496
    The actual valve nuCamp uses is the La Salle Bristol (rather than the far more common Valterra, for some reason). Amazon doesn’t seem to carry just the handle, so if you want an exact match, you’d have to buy the whole set. https://smile.amazon.com/gp/product/B003VAYXR2/
    The Valterra or Camco replacement handles should still fit though.
  • mandt
    mandt Posts: 158
    Thanks VictoriaP
    Mickey & Terri
    2016 Max S
    Kalamazoo Michigan
    qhumberd Posts: 871
    Amazon to the rescue!. They apparently now carry just the handle for the valve. The one on my 400 just broke.
    https://www.amazon.com/gp/product/B007HRMZC0/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
