toolkit recommendations
rhyno
Member Posts: 393
I have put together tool boxes in the past for larger RVs but for the Tab we have on order, I'm wanting to downsize to save space. Does anyone have a recommendations of a general purpose, ready-made compact/travel tool set?
Depends on what you need.
The T@Bs have those wonderful square hole screws
, so you need a driver or bits to fit them.
Other than that I would venture to say not much different/less than you have in an RV.
I've got the bits, hammer, hack saw, snips/cutter, sockets for the lug nuts and a breaker bar, tape, rubber mallet, couple of different pry bars.2006 RAM 1500 4 door, 2016 T@B 320 MAX S
Tampa FL -
Do a forum search for tools. I know there is a thread here.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Duct tape & a hammer, that’s all that is needed! 😂😂TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback -
Basics, screwdriver(s), a high quality adjustable wrench, pliers, electrical tape, test light, gloves (in case you need to change a tire). Jack, lug wrench that fits. That's about all you really need.
Brad2020 400 BDL aka "Boonie"
Concord, NC -
Socket for lug nuts and a torque wrench. We are supposed to check that and it is now my lug wrench.
Harbor freight has a Super coupon right now for a 1/2" torque wrench. $5 with coupon!
I needed a 3/4" thin wall deep socket for my Tab400 BDL. Also a short extension to clear the tire.2019 T@B 400 BDL 2017 F150 3.5L Ecoboost
Jeff & AmyNow in Manistee, MI -
I would second the jack, but note that the lift point for tire changing is a steel lip right behind the tire on our 400 and not very wide so make sure your jack can fit and engage safely when the tire goes flat.2019 T@B400 Boondock Lite "Todd"2016 Toyota Tundra 5.7 Crew Cab
Towed by 2014 Touareg TDi -
I have a month long trip planned in September and would like to prepared. Got fuses and these screwdrivers on order
https://www.amazon.com/gp/product/B014US2CDA/ref=ox_sc_act_title_1?smid=A28MCPZHAOVXV&th=1
Also superglue, Gorilla tape.2022 T@B 320 S Boondock "UGA", Jeep Gladiator Overland
North Georgia -
The first thread when you search “tool kit” also has a ton of good recommendations. https://tab-rv.vanillacommunity.com/discussion/8223/tool-kit2019 320s BD Lite, white with blue (“Haven”)
- 919 Introductions
- 407 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
