I have noticed there is water dripping underneath where I plug in my 30 amp cord. I investigated today and there is a tube there I’m wondering what the heck that drain tube is for and or if this is related to the dripping I have underneath the outlet
Check under the driver's side seat/bench to confirm that the drain valve for the hot water line is completely closed. Also, the drip may be associated with too much pressure in your Alde hot water tank (assuming you have recently used hot water or heated up the water.) Open the yellow flapper valve (lift it up) in that compartment and release some pressure/water from the tank. Review your Alde manual, because it explains that you need to remove some of the pressure from that tank by opening the Safety/Drain valve (yellow flapper) approximately every 10 days to create an air cushion above the water in the tank.
To identify the different drain tubes and water line connections, open the "User Manuals/PDF Files/Videos & Resources" folder on the left side of your screen and download the "Plumbing Compartment Components (320S)" .pdf document.
They are "low-point" drains because they are supposed to be the lowest section of the water lines so you can easily drain (most of) the water from those lines. In reality, they are not actually the lowest location (but close enough), because to really get all the water out of those lines, you need to blow them out with an oilless air compressor (or fill the water lines with RV compatible anti-freeze) when winterizing your trailer. If you have not tried winterizing your plumbing system yet, you will want to read up on the process. There are numerous discussions about it on this forum, plus resources in the folders on the left side of the forum pages.
If the drip does not stop, you will probably need to replace the hot water valve at the low point drain tube. Although I have had to remove and replace one of those valves, it should be a relatively simple and inexpensive task if you are comfortable doing that. Otherwise, you can take the trailer to a T@B dealer or RV repair shop to have that done.
