Just picked up my 2021 320S Boondock. The dealer (200 miles away) installed a mystery battery--no-name, undefined capacity, which will need to be topped off with distilled water from time to time.
I'm suspicious, and my first Boondock upgrade will be to an AGM battery. NOT lithium for all the usual reasons.
The question is--what's an appropriate capacity in amp-hours? My boondocking plans will mainly be 5-6 days in the high plains (5500--7500 ft. elevations) of New Mexico at BLM sites (toilets only, if that) doing astronomy from mid-March through mid-November. Maximum draw will include the 12V fridge, interior lights, and the Alde system on cold nights, or the overhead fan on warm nights.
I will charge my 12V astronomical AGM batteries with a separate solar charging system, BTW. And, I will take along my mystery battery as emergency backup.
Thoughts? Thanks!
0 ·
Both trips were three days long. On the first, in late July, I hit about 50% discharge by the middle of the third day (measured to the best of my ability without a battery monitor). We had good sun for the first two days but rainy and overcast on the third. I used the refrigerator the entire time, the water pump, fan and some lights periodically.
On the second trip in mid October, we had very little sun and I ran the heat all night. Although I still didn't have a monitor, based on the indicator lights, I'm sure I was well below 50% by the third morning. I have a 100 AH flooded cell battery.
For this coming year, I have added an additional 200W suitcase solar panel, a Victron battery monitor, and plan to upgrade to (probably) two, 6V 230 AH golf cart batteries. I'm still trying to decide whether to buy the Trojan flooded cell batteries or go for the AGM.
Is '21 a two way or 3-way (propane) fridge ? Use propane if you have it.
Get a good sleeping bag and keep Alde off while sleeping.
Which means you have 35AHr of real power.
Suggest at least a 100AHr AGM and solar panel to recharge (some of) it during day.
If your Fridge is only 12VDC/120VAC then . . . it is sharp pencil time to find the correct battery capacity for that many days boondocking.
Adventures: 55 Nights: 376 Towing Miles 46,920
You will likely need to replace battery tray and box as you go to the larger AGMs, but the forum also has plenty of examples of people squeezing two standard size AGMs into their tub with a little surgery as another option.
Consider getting a battery monitor (Renogy or Victron) for your current mystery battery, and spend a couple days in a nearby park to see if you go through 20, 35, or 50Ah a day.
Each time you flip a switch, do you really need it? While Boondocking, do you really need the outside light on all night?
2. I'm gonna keep Alde on at night at about 65 degrees. That's one of the main reasons I bought this trailer--I'm tired of cold nights in the back of my Ford Transit van or in the alternative, running a propane heater with the attendant risks (and it only runs about 5 hours).
3. I do have a 100W portable panel (with Renology controller) which I use to recharge the astro-batteries. I'm wondering if after the astro-batteries are charged, I could connect it in parallel to the rooftop panels without causing damage either to the rooftop panels or the portable panel?
4. Saleslady told me two months ago the delivered battery would be 70aH, but nowhere does the battery itself say that. I certainly have my doubts--heck, the thing isn't even branded!
1. The first rule of astrophotography is--no outside lights!
2. Where I go, the main "zombie" risk is the occasional astro-guy or astro-gal wanting to look at my telescopes and other gear--they won't much care about the trailer. And because we all are up until the wee hours looking at the stars, everybody tends to sleep in!
3. I really like the idea of the solar powered lights. Presently, I have lantern which I can charge (along with my phone) from my separate 100W panel, but a couple additional solar-powered lights might make sense. Then again, how much power would the T@b's built-in LED lights use, I wonder?
4. I was planning to set Alde to 65-67 degrees at night, but I'll take your advice and set it lower.
5. Water pump will only be used for an occasional shower or for cooking. I like the idea of turning it off unless needed.
2. Waste management: I will use the BLM vault toilets, or failing that (they were closed last Spring for Covid), will dig cat-holes as permitted by the BLM. I really don't want to mess with black water, which is why I got the 2021, which has a cassette toity. But I don't want to mess with that, either--I only will use it if I can talk my wife into an Alaska trip. No way she would ever dig a cat-hole!
3. Re gray water: I need to figure out a solution, but while camping in my van I have never used more than 10 gallons of water on these trips--which I have carried in plastic jerry cans. I have just "donated" the water to the thirsty high plains vegetation. They haven't complained.
Bottom line, I take it, is that you get by with the stock (presumably 70aH) battery?
I am still experimenting with my 2 6v AGM battery set up and solar, but the 105w panel on the Boondock is not enough to keep up.
I have picked up.an additional 100w panel and charger but didn't get a chance to try it before the solar max values dropped for the winter.
I tried the Smart Energy module for the fridge from Isotherm, but it doesn't work. The fridge never turns off with it and my food all froze, so I will be having it removed.
The fridge is very efficient, but you need a little more solar than what we T@b owners have got away with in the past.
The 2019 T@B 400 had 235 aH of batteries and 200 watts of flexible solar panels on the roof, plus during one really low solar event, I added my 200 watts of glass portable panels. It did well.
Most people on this forum have 3way fridges so be sure to filter the feedback you receive. @Verna and @jkjenn are giving you good advice.
https://www.forbes.com/sites/rrapier/2020/01/19/environmental-implications-of-lead-acid-and-lithium-ion-batteries
No one had Victron products in their T@B when I got my 2014 so we all used cigarette plug-in voltage meters. The first person to add a Progressive EMS posted how to photos that are just like how it is done today. Technology grows quickly.
I would add, that a 100ah battery and the stock solar won't be enough to keep up with the phantom and fridge usage, let alone give you usable battery capacity with T@bs running the Isotherm fridge if you want to dry camp for more than a day or two.
Verna's suggestion about sizing solar to battery capacity is spot on. I got away with the 133w solar panel on my 2015 T@b and using the fridge on LP. On my 2021 320, the solar panel is 105w. I need that second panel.
Sharon is also right about possibly not getting enough sun to recharge and needing a little extra capacity for those days.
Don't forget time of year and latitude, too. Where and the time of year that you camp has an impact on your solar yield.
It really does take some trial and error to work things out to meet your own needs.
