The last 2.5 months have been a whirlwind of panic stations, learning, and gaining familiarity with all the fabulous features of my (new to me) 2014 T@B 320 S. This forum has been a lifesaver and I'm so thankful for all the generous support you all have offered.
So... here goes, the list of upgrades I have accomplished by myself and with help from the RV dealer who sold me the T@B and now wants to become a local T@B dealer!
'Self' upgrades:
- replaced the original elevator table with a removable slatted system to support the bed.
- installed a Lagun table with a reclaimed, light maple tabletop
- replaced the wet cell battery with a 100aH Lithium battery, because I am mainly a boondocker.
- added a propane tank monitor
- added an on/off switch and battery monitor
- removed the tv
- added a mattress topper
- added 'D' cell battery powered fairy lights
With help from my RV dealer:
- installed a rain hood over the Fantastic Fan - a 'must have' here on the north Pacific coast
- installed a super nice wireless backup camera over the license plate
- pulled the fuse from the Jensen stereo - if it had bluetooth, it would be more useful to me, but mostly, I enjoy the quiet of the woods
- knick knacks, such as fixing faulty tail light wiring and replacing the cap on the city water intake
Upcoming...
- there was a bit of a sale on Renogy suitcase solar panels, with a built in waterproof controller, so I'll be trying that out soon! Looks snazzy!
- make some window shades
- fix the broken end cap on the sewer hose
- boondocking shake out trip #2
Here's a few photos of Sunny with her new rain bonnet and back up camera
I'm going to go ahead and use it 'as is' because my particular license plate (British Columbia) has the word 'trailer' at the top which is less crucial information than the province/state name, which is fully visible.
The camera has a swivel mount and so I've been wondering if the bracket could be mounted some other way. Perhaps alter the bracket so that the camera is positioned off to one side of the license plate light housing?
Here's my original post:
https://tab-rv.vanillacommunity.com/discussion/12732/less-ideal-than-hoped-wireless-backup-camera-attached-to-the-license-plate#latest
The rain hood was a-mazing!!!
I'm just gearing up for shake out trip #3 and have new gear nets from https://www.organizedobie.com/ and small trifold foam mattresses instead of the memory foam which took up way too much room. I haven't tried out the solar yet. It's still pretty rainy here and the lithium holds its charge so well that it's still fully charged!
It came with a similar camera to yours. In the manual it said if I email them they will send a free second wireless camera.
Have a choice of an RV one that looks like a toy block with an antenna or one like yours but with a smaller single hole bracket. I'm opting for that one because the RV one looks like it would go up near the roofline of a larger RV.
Do have to hop thru a few hoops to get the free one. They want a review on Amazon with pictures, then a screen shot of the review sent to them.
It's been rainy here in FL so I haven't had a chance to install it. The original camera like yours is going on my truck, and the free smaller one is going on the T@B when I get it.
I did hook up the camera/monitor sitting inside of the truck and the images were really good.
Tampa FL
I purchased it online and then took it to my rv dealer for installation. It comes with everything you need to easily install it on an existing Fantastik Fans with no added drilling. I've been out with mine on 3 trips now and rain is a non-issue! I keep the vent open constantly. No condensation build up, even on damp, cold days.
https://tab-rv.vanillacommunity.com/discussion/comment/111606#Comment_111606
I'm hoping this new water saving attachment will add some water pressure, allow me to redirect the stream, and also deplete the little 5 gallon tank less quickly!
I'll be trying this out on my next 'local' trip, 12 days from now...
The one I have allows you to switch between a stream and a spray.
Mine is a non screw model fan, not sure if this cover would work? I do not have the 4 tabs on the roof.
Tampa FL
Since my fan doesn't have screws, I don't know if the cover you got will fit, and I know the 4 tab model definitely won't.
None of the info I can dig up on the one you bought mentions about using it on the no screw type of fan.
I did see a Maxi Vent type that screwed into the sides of a fantastic vent, but it was only for a non powered type.
Tampa FL
1. I bit the bullet and upgraded the foam seating cushions to denser, poly-wrapped foam - just in the "U" shaped sections of the seating - 6 cushions total cost me >$400. Very worth it. I will still use a memory foam topper, just to keep the sleeping surface separate from the uphostery.
2. A cigarette lighter type USB adaptor so that I can charge my cell phone while boondocking.
3. A 48" (max) curtain rod so that I have a place to dry towels. I'm going to try mounting it at nighttime, above the galley and take it down in the morning.
4. In progress: I'm getting a friend to paint a work of art on the gray fridge door and side panel. The design is in the works, ETA is October!
5. I've also had 3 or 4 trips where I've used all the plumbing, including the black tank. Such a treat! The 2014 has tiny tanks so I extend them by keeping TP out of the black tank, whenever possible. I use a "smart siphon" to top up my fresh water and an 'oil pan try' to empty gray water in smaller quantities. The Alde hot water boiler is impressive! Near on-demand hot water, even for those luxurious longer showers.
Just 3 more sleeps until my next trip. I'm super excited to be going back out to Pacific Rim National Park. I was lucky to grab a cancellation! And I'm really looking forward to a more comfortable night's sleep with the new foam.
