While Thetford Cassette Toilets are being used more and more in US/North American market RVs, we lack the standardized cassette dump points here. You can dump them in a standard toilet, a pit toilet, or try to get the cassette discharge pipe into a standard NA RV dump connection, designed for a 3-inch sewer hose connection, all messy and sometimes smelly options. Some have made their own adapters to connect the cassette to a standard 3-inch RV sewer hose connected to the RV dump port.
There may be a commercial product to connect the cassette to a standard 3-inch RV sewer port. James at FitRV has come up with a one piece adapter to make the connection from the cassette to the 3-inch sewer hose, he calls the
Americanizer, see his site: s://www.thefitrv.com/
Americanizer
He also posted a video showing his adapter in action:
https://www.youtube.com/watch?v=YHRiCzLV2fkcheers
Harpers Ferry, WV
As with Jackie_Dave, this would open up a number of RV models I currently wouldn’t consider as they don’t offer a black tank option. Prior to this, the only way I’ve thought of to get around the weight issue that doesn’t involve dumping every day is modifying some sort of SUV dog ramp to get the cassette to the ground for dragging to the dump station.
TBH, it feels like a solution in search of a problem.
I have personally visited two different RV Parks, one County and one KOA, that forbid dumping cassettes into FHU drains or the common area dump station unless a smell & leak proof connect was used
One location sold an adapter, the other refused to rent to Cassette Toilet rigs.
And yes, one disadvantage to cassettes in the US is that some careless people have already spoiled the experience for others by making a mess when dumping them in sewer drains or toilets. It’s been reported by some already that certain campgrounds have turned away campers using them (typically private campgrounds, but as MuttonChops noted, some public). I’ve personally seen signs at others where dumping is not allowed in campground bathrooms. Others have seen similar signs on vault or pit toilets...maybe due to too much waste being added too quickly? I’m not sure.
If anyone has any doubts of how painless it is to dunp at a FHU site, I demonstrate it on my YouTube channel.
If you’re out boondocking, you can spend a night at a campground or RV park, sleep and dump your tanks plus fill up with water. That’s really getting your money’s worth.
Dumping our cassette toilet hasn't been too difficult a task, but I'd buy this adapter for occasional use at dump stations with a foot cover. It seems well thought out and a clean option with a little less mess risk.
Golden, CO
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
MOUSE-KE-T@B
Harvest, AL
You will always run into places that won't allow you for different things: size, age of trailer, age of campers, dogs, breed of dogs, not fully contained, cassette, porta-potty, etc. I have found them to be the exception, not the norm.
we have two resort type RV parks, with full hookups along the Noyo River, and they allow the small park model RVs, which are not self contained at all. My 1958 Kenskill trailer was a Vacation Mobil Home unit, it was a full 8-feet wide by 28-feet long, and was not self contained, required full hookups. It was designed to be located in a resort RV facility or setup as a semi permanent vacation cabin.
Incoming RV’s, motorhomes and travel trailers must be in good condition and self-contained.
https://koa.com/campgrounds/laughlin/?utm_source=campgroundreviews.com&utm_campaign=RVLife_Campgrounds&utm_medium=referral
SELF CONTAINED units only. Pool: Open all year. Max pull thru: 90 feet.
Please Note: We do not allow Tent Camping or Pop-Up Tent Trailers that do not have sewer connections. To stay in our campground you have to be fully self-contained (you must be able to hook up to water, electric & sewer.)
Here are two parks. Full hookups, but require self-contained units.
MOUSE-KE-T@B
Harvest, AL
Has anyone experienced the poop police cracking down on this practice? Or been turned away at check-in due to a trailer inspection that revealed a cassette was present?
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
