Water leaking at wheel well
davidandsharon1
Member Posts: 1
2020 T@B 320 CS-S, driving in the rain, water leaks in and around the right side wheel well area. Difficult to tell exactly where. Bought this January 2020, so I guess out of warranty. Advice on re-sealing this area? Should I contact service? Replies really appreciated.
I'd contact the dealership and also nuCamp warranty folks before attempting repairs yourself. It's possible nuCamp may assist. They do have a history of doing so after the warranty has expired.
It's worth a shot. Nothing ventured, nothing gained.2020 T@B 400 "OTTO" (build date 08/19)
San Diego, CA
www.airbossone.com
https://fineartamerica.com/profiles/owen-ashurst/shop -
Welcome to the Forums....Wheel well leaks used to be reported more often several years ago.Here is a thread from last year that might help with your search for the leak's source: a 2014 with a problem like yours. Take a good look around in the wheel well area from both sides, shine flashlights outside while someone looks at the area from the inside, etc. Some other thoughts about where water intrusion happens in the thread. There is also a "caulking guide" thread linked which will give examples of the caulks to use in various parts of the trailer.
Towed by 2014 Touareg TDi -
This may help: https://tab-rv.vanillacommunity.com/discussion/2895/attention-special-factory-maintenance-notice/p1?new=1Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Also, nüCamp recommends inspections of,the wheel well seams in o be sure they are still caulked, on an annual basis. This could be the source of your leak.
cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.
- 916 Introductions
- 72 Teardrop Groups & Links
