DesertDweller
Member Posts: 129
Hello all. Please allow me to pick the brain of the solar power cognoscenti. Sorry for the long post, but I think full info would help in understanding my issue.
I have a 2019 T@B 320s (BD lite) with the factory installed solar. The panel is located just behind the covering for the vent fan. Creed once informed me that it is a 110 watt Sunpower panel.
I recently installed a Battle Born 100 Ah battery. I have the Victron 75/15 MPPT solar controller and the 500a/50mV Smart Shunt. Since my Li battery install, the controller never goes into absorption or float mode. (It worked fine with the SLA battery). Further, even in broad AZ sunlight, the controller will indicate intermittently that the charger is “off” due to “insufficient PV voltage.” At other times, it shows the charger in the “on” state and in bulk mode. As a result, the battery gets charged but only to about 13.18 volts or so which according to BB is about 70% or thereabouts.
I have confirmed with BB that my settings for the controller and shunt are correct for the battery. Unless I am missing something, that leaves me with a wiring or hardware problem. I have double checked all the connections I touched during the install and they appear to be correct and tight. I am wondering if, by coincidence, the OEM solar panel (or other hardware) began to fail at the same time I did my install. I generally do not believe in coincidences, however. I think it more likely that I did something wrong somewhere.
But, to rule a failing panel out, am I correct in assuming that the two 10 GA wires underneath the bench on the driver’s side and that connect to the PV terminals on the solar controller run directly from the panel through the double cable entry gland on the T@B roof? In other words, if I put a voltmeter directly on those wires while the panel is in full sun, would I be testing the PV panel output (as well as the wiring from the panel and entering through the roof)? If so, what output readings should I expect from the panel in terms of volts and amps?
Given the lack of entry into absorption or float mode, what other tests I should be doing? How do I check the wiring running from the cable entry gland through the T@B roof, down the inside of the wall, and emerging near the controller? Is it possible I loosened a connection when I was connecting the PV wires to the controller (it took quite a bit of effort to fit the 10 GA wires into the Victron terminals on the controller)?
Thanks for reading and any suggestions you may have.
Z
2012 Jeep Liberty KK a/k/a "Libby"
You didn't list the shunt current while this is going on, knowing this may help troubleshoot. Also verify there are not excessive loads connected in the trailer. I think if you switch OFF the battery and monitor the shunt, the panel should still attempt to charge the battery only - not the trailer loads - the shunt will still display the battery current situation. Good luck.
managed by VE Smart Network
Concord, NC
The first image is of the shunt readings with the PWM controller in full sun, (but not directly overhead) and with the battery disconnect switch activated (no juice going to T@B systems). The PWM controller indicated it was in "boost" mode which I think is the same as bulk.
Then, while I was there, the PWM controller switched to "night" mode meaning it thought there was not enough sunlight to generate a charge. I am equating this to the Victron's message that tells me the solar charger is "off" because of insufficient PV voltage. Here is a shot of the shunt readings during this condition.
Then, as @DougH suggested, I put the battery under load by deactivating the disconnect switch and putting my three-way Norcold in "battery" mode. The PWM controller was still in "night" mode during this situation and I took the following screen shot of the shunt reading.
While I was there the PWM controller never went back into "boost" mode. But, I did not stay long as I had to get to my desk. (Of course, I am there now typing this, so I guess I am working through lunch!
Any thoughts would be appreciated.
As MarkAI explained, without the load, and at a battery voltage of 13+V, any controller will report a 15-20V voltage, but hardly any current or wattage since there's simply no need to charge such a full battery.
Above and beyond just knowing the PWM boost versus night mode, which certainly points to the solar panel or wiring or any MC4 connectors, does that original PWM controller show you voltage and current from the panels to echo the "insufficient PV voltage" you got from the Victron MPPT? Even if it doesn't, it sure sounds like you've likely ruled out the controller. I keep a spare controller for the same reason.
If there are any MC4 connectors on the roof near the panels before the wires go inside the camper, you could check the voltage there in that same bright AZ sun (envious). Likewise if there are some connectors up there you can do a resistance / continuity check from the connectors to the wires at the point where they head into your controller to check the wiring.
Flexible panels can be easily damaged by hail and other environmental conditions, but only getting a year or two of life is very much on the shorter side of average life expectancy.
Not sure which is the least effort, replacing the wiring and re-Dicor-ing any entry point... or replacing the panel. But before doing either, I'd get the actual voltage number in full sun from the leads, or at the connectors on the roof if it has any... as well as the continuity check.
"The big issue you'll need to consider is voltage differential - the MPPT requires battery voltage + 5v from the solar array to turn on and start charging (ie, if your battery voltage is currently 13.2v, the controller needs to see 18.2v from the array to be able to start charging... which many panels will not themselves be putting out). With a Pb battery this isn't such a concern, but since LFP batteries have a much higher resting voltage, this can be an issue when trying to charge from a single panel: you'll want a panel with a VOC of at least 36v to ensure that you can start charging as early as possible and continue charging as late as possible!"
Here’s more of the conversation.
Victron dealer: “So no, once the controller is charging, it will continue charging as long as there is at least +1v differential between array voltage and battery voltage, so that's not bad - it's the initial trigger that requires that high differential.”
I suspect your problem (if in full sun) is not the voltage limit of the panel, it will be a factor with the BB battery, but only limit how rapidly they were charged. Once the voltage starts dropping significantly on a panel the issue will be lack of solar collection.
I have 2 controllers - one for the factory installed panel and one for the remote panel(s). I then series or parallel these based on the solar situation. Then each controller works the panels independently. I can charge in very low light situations but in the winter and w/ trees at best not more than a 10-30 watts (for 4-5 hrs) at times. Yes the hassle is rarely worth it. It does extend the time I can go without a generator or turning off the refrigerator...
I have 2 Victron Controllers connected to create a network. This seemed to work well.
aka BirdieJane towed by Quinn
I then removed the 12 V TV and the plastic housing for it to see if I could trace those wires. I found them and they went into the A/C cabinet. I removed the A/C as much as possible as one person can do, and saw where the red and white wires were connected to the two wires that were coming in from the roof, presumably from the double entry gland where the panel wires enter the roof. The connections looked good as best I could tell given that I was holding the A/C on my knee with one hand. So, unless something is wrong with the wires from the panel entering into the roof, I think my panel may be shot. I am not really sure how to test the panel itself.
By the way, does anyone know if NuCamp used adhesive on the T@B 320s solar panel (installed behind the fan vent) in addition to the four corner grommets and screws in between the grommets?
