Anyone else experiencing this on their brand new 2021 nuCamp Tab400 Boondock? Is this common for nuCamps? We got this new trailer and the bolts holding up the black panel on the underside keeps breaking off. We tried to remove one with a hand wrench so we can replace the 14 that broke on the drive back to our home and that bolt broke with one simple twist by me. We tried another and that broke and another I just tapped and that broke. Will more keep falling off? Any tips to fix this?
What should I do to get the broken bolts out? How does it corrode so fast? Did nuCamp use the wrong bolts for an exterior? Will the rest of my black underbelly fall out during a drive? Isn’t that a hazard?
And I'd not go much further with repairs unless and until you've resolved all the warranty issues related to this.
San Diego, CA
www.airbossone.com
Certainly notify nuCamp.
Since so many have failed on this one trailer there is likely one common thread (no pun intended), which may extend to others coming off the same production line.
As an individual who spent most of my adult life investigating transportation accidents for the National Transportation Safety Board, I implore all Tab 400 owners to inspect your trailers to determine if you are missing any of these bolts. If this is a wide spread problem we need to make sure that NuCamp is not only fully aware of it, but also takes the required corrective action.
If the underbelly panel where to separate from the trailer while it was being towed, it has the clear potential to result in a multi-car catastrophic event!!!
I have sent a message to nüCamp. @LammyWinn, please call nüCamp Customer service tomorrow morning and have your name, address and VIN number of your T@B available. They can only help if they know about it.
I replaced what I could under the trailer with stainless steel screws.
Another testament to their poor quality control...I found protective glasses and LOTS of screws when I took off the under panel...which is corrugated plastic. I also have not heard back from NuCamp.
I posted two photos, but it kept getting taken down.
To reply to @rhyno...If I knew then what I know NOW with ALL the problems we encountered with this trailer, I would not have purchased this trailer. Overall, it has been one big disappointment.
Can understand your disapppointment. Reach out to nuCamp Customer Service first thing in the AM and advise them of your issues, again if necessary. It certainly doesn't sound like SOP for nuCamp. They will take care of you, though. They do have that history.
If you've found other issues from the factory perhaps you can share those as well so that others who own a '21 400 BD are made aware. As @Verna mentioned above, nuCamp can and does assist in these matters so long as they are made aware of them in a timely manner.
Good luck and here's hoping you resolve you issues soon and are back on the road again.
San Diego, CA
www.airbossone.com
As for your photos getting deleted, they were probably over size, you need to reduce the pixel size/resolution to a medium quality before posting them. See posting photos at the top of the forum main page.
Sounds like nüCamp ran out of galvanized screws, or had a bad batch of replacement screws that were not up to snuff or galvanized. I agree stainless screws would have been better. Since you are in NorCal Bay Area, did,you get the trailer from a local dealer? If so, you should be able to get them to sort out all the issues you have been having.
I listened to a podcast about the decline of Detroit auto manufacturing in the 70s and dealer service stations used to find tools and garbage in the door compartments of new cars. Stuff like this is inexcusable and pretty embarrassing for Nucamp.
2020 Tacoma TRD Off-Road
The OP has decided to sell his/her TaB, rather than deal with a few minor issues.
I had to deal with a floor replacement, that nüCamp provided without any issues. or questions. Their service is second to none, and you are not going to find a better product anywhere else. Sure there are issues, mistakes are made, but nüCamp stands by their product and customers. And as Verna said, nüCamp can’t help if you do not ask...
I agree you should not have to crawl under the TaB and replace all,the sheet metal screws thst are holding the underbelly panel in, nor should you have to worry about the heating system not working correctly. We are all here to help as a group, and according to Verna, nüCamp wants to help you sort this out. Sometimes it takes more than just one call, try giving nüCamp another call to customer service, from the nüCamp website, “If you need assistance, please contact Customer Service at (330) 852-4811.”
What was the issue causing the floor to bubble? Did Nucamp replace the vinyl flooring, or the actual floor itself?
I have noticed a bubble near the dinette table leg on several occasions on my 2021 T@B 400 BD (like you, only when the interior was hot), but it goes completely away when the interior is at a normal ambient temperature - so I haven't paid it much attention. But if they replaced the floor due to this, I guess I need to investigate further.
This is the same mentality that we all take with contractors. The bar is so miserably low with most trades that whenever one comes along that does a "decent" job we're ecstatic. Take that same guy and put him in an industry with a higher level of expectation and they'd drown. That's not to say there aren't amazing contractors because there are. It's just more the exception.
As a future owner of a 400 I am a bit on edge as I see people on the forum voice concerns about little issues turning into larger issues. I've gone through this already with the Forest River tent trailer we own now. Different animal but the quality is abysmal and I spent a lot of time rectifying many of the deficits it had from the factory. It was junk.
I'm still hopeful but I do feel like @LammyWinn is justified in her frustration. These aren't cheap trailers and they really should be flawless out of the factory door considering their mission statement is about quality. Like I said earlier, these are rolling advertisements for a fairly young, small RV manufacturer that is capable of doing some awesome stuff in the future. Now's not the time to be skimping on quality in favor of profits. Let Forest River do that.
We actually may have hung out in your exact trailer on their lot. I think that configuration was the only one they had there at the time (we were there maybe in late November).
The Alde has a fairly steep learning curve, and is not very intuitive. Give the Alde manual a good read, and ask questions here if necessary.
When I took it in they tried to replicate the bubbling by bringing it up to 88 deg. They could not replicate it. When we had bubbling, I feel sure that the interior was a bit hotter than that.
They suspected that there was less glue in that spot. Ours was just outside the bathroom door and the fear they had was that there would be water damage. They did not find any water damage when they took it out.
They took out the underlayment and vinyl flooring and replaced it all. The floor looks perfect. They completed it and the other mods in 3 days. Austin took the time to answer all questions and the service dept was great.
We tried to get the floor fixed locally, but our nuCamp dealer who lives ten minutes away refused to work on it because we did not buy it from them. Actually he said he didn't want to work on it but would 'work it in if he had a chance in a few months'. His response to us did not give us confidence in having it done well.
We made the decision to take the trailer all the way back to Ohio, a 3000 mile round trip. It was planned as a Christmas break vacation but because of covid, I had to travel without my wife. A son joined me midway and it turned out to be a great trip.
Long story to say that we took it back, we are glad we did, and the nuCamp crew did a fantastic job.
Thanks.
I've observed the bubbling after driving in the 90+ summer heat, where the interior was over 100...so I agree with you that 88 probably wouldn't reveal the issue.
Guess I should give nucamp a call and talk to them about this, because I have that exact same issue, and if that requires a new floor, I sure want to get it on record while it is under warranty.
I do wonder what happened with the 2021 models during assembly that is leading to this issue.
The Alde finally worked in providing both heat and hot water after adjusting everything and attaching a hose that wasn’t attached going into the Alde. The hose was pinched shut (capped?) but was left lingering just under the Alde. QA issue I guess.
