Inside Door Panel Gone Bad - SOLVED
13»
  • Bayliss
    Bayliss Member Posts: 1,531
    Excellent work, @Tabaz.  A very clean job.
  • Marceline
    Marceline Member Posts: 1,760
    Looks great!
  • gulfarea
    gulfarea Member Posts: 524
    That looks like it should be there, great work, Art
    2019 TaB 320 S Boondock Edge
  • Leeza888
    Leeza888 Member Posts: 7
    @Tabaz nicely done!  Wow! I'm going to try this too, and then add baskets :)  Thanks for sharing the information and for the contact at Challenger Door.
    2017 T@B S & 2012 Jeep Wrangler Unlimited
    Nights: 1
  • Tabaz
    Tabaz Member Posts: 2,420
    Thanks everyone!  We'll see how the wallpaper holds up in a camping environment.  If it starts to fail for whatever reason, then Dale's suggestion of using countertop laminate would solve the problem.  As a side benefit, the current wallpaper would make a perfect template for cutting the laminate.  I must say, this looks so much better than that white plastic.
  • Lil_Lucy
    Lil_Lucy Member Posts: 82
    @Tabaz, good job. Ironically, that was the same pattern I was contemplating using. (great minds think alike). You’ve given me a great visual of what mine would look like.
    2016 T@b 320 Max-S (Silver/Red Trim) / TV: 2019 Ford Flex
    "Growing old is mandatory. Growing up is optional."
  • Lisamorrisette
    Lisamorrisette Member Posts: 48
    Tabaz, that is beautiful. I have no cracks but it makes me want to dress up my little bug. LOL I’m still finishing up the directions from one of your other mods. I did make your twin beds and took it out on a trip to Arkansas worked wonderful. No I am trying to replicate your narrower back cushions as I had no place to put them when we slept. The bathroom had the cat box, the 2 dogs were on the floor the first night I shoved them in the kitchen space but then coffee in the AM was a problem. So night two they were in the TV. Anyway great job on the door.
    Furbug 2014 T@B S - TV Toyota RAV
  • Tabaz
    Knowing how easy this was now, I would have done this mod even without the cracks years ago.  BTW, its holding up very well.  Too campouts under my belt and no bubbles, bumps or cracks.  Still looks great.
  • WY320Camper
    WY320Camper Member Posts: 5
    Nice Job and looks better than old barn wood too!
  • AnOldUR
    AnOldUR Member Posts: 1,755
    Long shot question. Has anyone bought a new door and still have the old one? I'm looking for a pre-2020 320S door in any condition. Thanks.
  • BrianZ
    BrianZ Member Posts: 1,770
    @Tabaz , just to confirm, did you use the wallpaper color called "Cream" or "Modern"?  Thanks.
  • Tabaz
    Peel & Stick NuWallpaper by Kelly Ripa Home. "Grassweave."
  • ChrisK
    ChrisK Member Posts: 280
    That looks great!.
    BTW - You've been slacking on your stalking of us. We have been camping several times recently and you weren't there. What gives?
    2014 T@b S Max AKA T@dpole
    pthomas745 Administrator, Moderator Posts: 4,622
    @Tabaz, how is your door solution holding up?  My 2017 is a bit crinkled, and a conversation came up on one of the FB groups today about this same issue.
  • Tabaz
    Still looks great after over four years of use.  No peeling or shrinking.  Plus, the white board behind the new facia has not deteriorated any more since putting it on.
