Need some detailed info about recommended products, tips, tricks etc re washing/waxing. I comm'd w Creed, the tech at NuCamp as well. As usual they redirect to the Forum. He did say using dawn dish detergent is ok to wash exterior. (I have a friend who says its not good for the finish(??). Creed also recommended Maguire's wax (NOT POLISH!).
What are people using that works well without deteriorating exterior elements or affecting factory striping/decals.
Is using an electric orbital buffer ok?
How to remove the dark streaks, ie below windows? Another rv user said use Awesome Orange, but when I went online to read user comments, they were quite mixed, with plenty of warnings and cautions.
Since the roof is aluminum(??), should a different waxing product be used vs the sides?
Is Simple Green an acceptable spot treater?
Very open to advice!
Simbionic
Tab 400BD
TV: 2013 Lexus GX460
0 ·
Once it was clean and dry, I used a car wax with an orbital polisher.
I did this in October before putting the trailer into outdoor storage. It’s nearly March and the trailer looks great. Water still beads off the exterior. Unless I learn that this process is not recommended, I will do it annually.
Tab 400BD
Someone recommended a product called LA's Totally Awesome, and sure enough I found it super cheap at my local Dollar General. Spray it on, let it sit a minute and then rub. Amazing!!
Tampa FL
San Diego, CA
www.airbossone.com
Boston Northshore
One warning about using public self-serve car wash sites. The dirt/grit on the brushes used by others to clean their vehicle can scratch the Lexan acrylic windows on your T@B.
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
Boston Northshore
2024 Toyota Tundra SR5
