We'll be picking up a 2020 T@B 320 S next week and would like to have some accessories ready ahead of time. What I can't find here or elsewhere online is if the 2020 320S has an external propane connection for my Blackstone grill. I think the CS model does, but not sure about the S. Can someone let me know if it does or do I need to put a "Y" splitter at the tank? Thanks.
I use a splitter at the tank to feed unregulated propane to my Weber Q. After a few years of this I noticed the flame wasn't getting very high. Upon disassembling of the Q's regulator I found it full of an oily brown liquid.
Some sources suggest this substance originates from the tank, but others say it leaches from some types of flexible hoses when used with an unregulated propane source. Just something to be aware of depending on how you decide to fuel your Blackstone.
The hose from my regulator runs to an iron pipe under the T@B from which flexible lines to the stove, fridge, and Alde branch off. I wonder if I could incorporate such a splitter to also feed my Q.
Those of you with new (2021?) models having the auxiliary propane port, can you describe how and where it is connected into the system?
