After staying in Florida to wait out winter, I’m leaving for Arizona Monday. As I will be doing one night stays in campgrounds ( hopefully if they’re not full) I have to face my nemesis head on....the dreaded coupler!
Every time I have had to hookup/unhook it has been a project, up to 45 minutes on one unhook. Even when I have had help from experienced campers they have struggled! Hooking up has gone better since being told to lift and set back and down the “lock/cap” but unhooking is always a crap shoot.
I had and towed a horse trailer in the past and never had a problem but it was a different type of coupler. Any advice? And thanks!
2021 TAB 400BD; 2015 Audi Q5
Boston Northshore
0 ·
https://tab-rv.vanillacommunity.com/discussion/6974/someone-say-it-ain-t-so-please-t-b-hitch-challenges/p1
https://tab-rv.vanillacommunity.com/discussion/comment/83154#Comment_83154
https://tab-rv.vanillacommunity.com/discussion/2739/very-stubborn-trailer-hitch-coupler/p1
The best advice I can give is that when you park wherever it is you want to unhitch, pull your tow vehicle forward slightly and set the parking brake (to prevent the vehicles from rolling.) That will move the hitch ball forward and away from the locking mechanism in the coupler. If the ball is pushed back against that mechanism, it is difficult, if not impossible, to unhitch. For example, if you back in to a site that is slightly uphill, the hitch ball will likely push back against that mechanism. Pulling forward helps relieve that pressure.(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
I didn’t know that I should be lubricating the coupler. What lubricator should I get?
Boston Northshore
When hitching up, pull the latch back and move the tow vehicle to a position that aligns the hitch ball under the trailer coupler. Then, lower the coupler onto the ball and re-engage the latch to lock the coupler to the hitch ball. If the latch will not properly engage, first try cranking the post back up and then back down to see if it is just slightly off. If that does not work, crank up the trailer post and slightly pull the tow vehicle forward, or possibly backward depending on where the ball is situated in relation to the coupler, before again trying to lower the coupler onto the hitch ball. You may simply need to release the parking brake to see if that helps the coupler properly align and engage with the ball. Often times, it will only be out of alignment by about a 1/2" or so. Sometimes, I can get them to properly align by simply stepping onto the tow vehicle bumper to lower it a bit, but I have always towed with a pickup truck, so that is not as easy to do with an SUV, or similar passenger vehicle like yours.
Whatever approach you try, it always helps if you have an extra person to keep an eye on things, if that is possible. Regardless, the old tried and true trial and error will ultimately reveal what works best for your particular set-up.
I'm also new to coupling/uncoupling and perhaps others can confirm if this is a good or a bad idea: before I uncouple, I place chocks behind the RV wheels, because "gravity".
When coupling, I remove the chocks in front of the RV wheels so that the trailer can move forward a bit when latching on. I leave the rear chocks in place until I'm fully coupled to the TV.
I'm definitely going to try @Bayliss' advice on my next trip and pull forward a bit before uncoupling
Often times, once you unhitch after chocking your wheels, pressure will be applied to the wheel chocks and you cannot easily remove them when it comes time to hitch up before heading out on the next leg of your adventure. I prefer to leave the wheel chocks in place and make minor alignment adjustments (between the coupler and hitch) by slightly moving the tow vehicle forward or backward. Again, this is where a second set of eyes really helps with the hitching and unhitching process.
Boston Northshore
Without doing that first, there is pretty much no way to disengage the coupler latch, except possibly if you are on a very level surface and the hitch ball is not pressing against the coupler locking mechanism.
Boston Northshore
I wrangled with mine for the first few years--even resorting occasionally to the forbidden dead blow hammer--until I finally came to understand the design.
In a nutshell, you need to pull the ball tightly forward in the coupler to be able to lift the latch, and then back off just a bit to relieve the tension to be able to get the hitch off the ball. It's a carefully choreographed multi-step process that involves wheel chocks, parking brakes, and light touch on the gas pedal. A little annoying, perhaps, but it works every time.
https://duckduckgo.com/?q=atwood coupler video&ko=-1&iax=videos&ia=videos&iai=https://www.youtube.com/watch?v=Zq3f8b37laQ
