Would anyone know the rated axle weight limit for the 2021 T@B 400 Boondock Solo? I know that NuCamp made a modification to the axle position in the 2021 model. Also, I use a weight distribution hitch with sway bars. I think this might take a little weight of the axle as well.
0 ·
Your weight distribution hitch may actually add weight to the trailer axle, you do run possiblity of that.
see: https://nucamprv.com/tab400-camper/nucamp-tab400-specifications/
If you are close to GAWR of 3900 for your T@B you run the risk if reach and/or exceeding that...not a good plan for the life cycle of the axle.
With the proper TV capacity and load distribution there is no real need for a WDH.
San Diego, CA
www.airbossone.com
