so, wanting to reduce tongue weight by relocating my spare from the jack post to the rear, but also wanting to avoid the complication and expense of mounting a yakima-style roof rack through the spaced roof framing, I am wondering if this will work (not done yet-- this is a fantasy image):
I'd use something like:
Yakima Spare Tire Kit for EasyRider Trailer
8008125
which would spread the load... through-bolted through the plywood backer on the downward sloped rear panel, with a plywood gusset plate at each mounting point. It might even be just as easy/better to make something similar to this which is a bit wider and longer if that would help.
With any encouragement at this forum, I'll send this on to NuCamp for their advice as well!!!
I've got two 6v agm golf cart batteries stacked in my tub (144 pounds! not a fantasy but a done deal), along with the stock 20 lb. propane tank. Life will be perfect if I just relocate the spare tire off the tongue-- and best if I can locate it behind the trailer axle. The issue is that my RAV4 has a max hitch load of 350 pounds and I'd like to be in the 250-275 pound range fully loaded. I seem to be just ok now, but would be happier with a lighter tongue load.
Seriously, your proposal does put it a little further back than the original design, and I don't believe there is much substance or framing to that plastic tailpiece that would support the weight of a spare tire bouncing down the road.
Funny how the pendulum swings. A few years ago moving the tire to the tongue was probably the number one mod owners made. Now with bigger tubs and bigger batteries putting more and more load on the tongue (and taking up more space) we are seeing recent discussions about getting the spare returned to the back.
Agree with ScottG about the lack of a solid substructure aft of the main frame cross member. Based on my experience working in that area, I recall there being nothing but wood and plastic in the location in your photo.
I've inspected the tail from the inside and can confirm there is nothing but plastic and air underneath it.
Tongue weight limits are what they are, limits. Many people are afraid to go to the limit. Engineers always built an extra degree of capacity to allow for human error or stupidity. Many times two or three times the posted limit. IMHO you should not fear taking full advantage of the limits the engineers build into there products. As long as your trailer is pulling without any sway or adverse handling characteristics.
