Just back from a 10-day trip and over the last few days my wife kept telling me she felt there was a small depression in the floor about a foot from the threshold.  While cleaning I ran my hand over the floor and yep, there is a depression.  I crawled under and removed a number of the passenger side screws from the rubber undercarriage cover so I could peek in.  Sure enough right at the dark gray tape I see a bubble about 8".  I can't see any damage, nor water lines etc., so I'm not sure how this occurred.  I sent an email to nucamp warranty and hope to hear back this week. We're planning a 8-week trip mid April so naturally we hope to fix whatever this is.
                2019 T@B 400 BDL
2020 Ford F-150 XLT (V-8)
Niceville, Florida
https://tab-rv.vanillacommunity.com/discussion/comment/159480#Comment_159480
This might be why they went from an all-Azdel floor to the luan floor in the 2021 model. Also, is that a seam I’m seeing in the pic? If so, why is there a seam there?
2020 Tacoma TRD Off-Road
While under the unit, have someone walk on the floor above to see what and where deflection exists; and if the tape indicates a joint in the flooring material - presumably you will see some deflection. Then cut a piece of 3/4 plywood to fit the area you have exposed below. If possible the plywood would best extend to any steel members nearby. Next, I would support the plywood from below so it is tight to the exposed floor. Then test from above for any deflection. If the deflection has been eliminated; then fasten the piece of plywood to the existing subfloor. If the subfloor is plywood, you could use a construction adhesive and screw to the plywood subfloor. If it is Adzel, do not screw into it as it has minimal screw holding ability - use construction adhesive and if possible a small steel angle fastened to the steel frame and new plywood piece. You might consider such an approach as an interim fix until you can get NuCamp to address the issue.
Richard
St Catharines, ON
Great idea. I'm moving it from it's current storage lot out to a nearby Military Base (after waiting 15-months) to a very nice secure storage lot. I'll remove enough of the bolts to lower the undercarriage cover to better inspect the area. I'm hopeful the metal framing offers a means to attach the 3/4 plywood. Confident the floor is Adzel. I have my fingers cross I'll hear something positive from nuCamp this week as well.
In addition to our 1-Year Limited Warranty, nuCamp agrees to warrant the structural integrity of the camper/trailer (roof, floors, front walls, rear walls, sidewalls, and hatch door, where applicable) for up to three (3) years from the date of purchase (Warranty Period). This does not include electrical systems, plumbing, or any system components or other items excluded under the warranty provided. 3rd-party components parts may be warranted by their respective manufacturers.
This warranty covers nuCamp campers/trailers manufactured on or after April 30, 2018.
2013 Tundra TRD 5.7L
Massachusetts
We spent three days visiting Yellowstone in July 2019 on our way from FL to AK. That trip was three months and truly the time of our lives. If our schedule holds true, we should be in Yellowstone the 1st week in May and while there will still be a chill in the air, we don't necessarily expect snow. Main reason was to avoid the mad summer rush of people. Now, our return will take us through ND and SD, so who knows what the weather will be.
