Looking for some suggestions as to why the ALDE heat is not staying on when connected to 120V house current. It runs perfectly fine on propane. It will run for about 5 minutes before shutting off when connected to house current. The breakers/GFCI connected to the house current plug are not tripping. I have the control panel set to 1 kW, night and day automation are off, thermostat is set 10 degrees higher than inside TAB temperature. I have alternated between gas and electricity as my priority setting, and this did not help.
I have tried the suggestions given too Verna from Creed in a 11/2018 discussion: “ As far is it not working on electricity - could you check to make sure you have had your Hot Water setting in the middle selection? If you have it on empty there will be no hot water or heat (not sure why its even an option), and when you have it on boost mode (full shower bar) it will only heat hot water and not heat the trailer cabin.” Trying this did not help.
2020 TAB 320 U
Thank you for any suggestions
TV 2025 Telluride X Type
Maybe try bypassing the EMS and see what happens.
Have you checked to confirm that the electrical plug connected to the Alde is securely plugged in? Maybe it came loose at some point. If it is loose, I recommend that you secure it similar to how is depicted in the photo of mine below.
This seems to have solved my issue, (don’t understand why)but the Alde has been on house 120VAC current for 48 hours without going off.
On the Alde panel I only turned the electric option on to 1Kw, gas option is off and no priority set. Then I physically turned off the LPG tank at the valve. I have tried this sequence before(Alde went off), with the exception of physically turning the gas off at the tank. Alde has been on all day. I have not physically turned the LPG back on at the tank valve to see what happens. That will have to wait until the weather warms up
Thanks to everyone for the time and effort to respond to my post.
Does the control panel turn-on?
What does it show? {you might have turned off the heating sources}
Do/did you heard the pump running (or the propane burner) ?
Does "house power" mean 120VAC power from a pedestal or similar source?
Also, are you using a surge protector?
