Tow vehicle's OEM factory brake controller not seeing the trailer brakes on our just purchased 2016 T@B 320 CS-S. Had the dealer check the tow vehicle, they say no problem. Where can I find the T@B's brake controller so I can take readings with a multi-meter to chase this gremlin down?
0 ·
Also, make sure that the vehicles brake controller is adjusted to apply more stopping force than it currently is doing. Maybe it's working, but just not applying enough pressure to the trailer brakes.
For the record, do you see the trailer lights coming on when you apply the brakes and do the turn signals work? Of course' those are different pin combinations that don't affect the operation of the brakes, but it does tell you that something is working, although maybe not the brakes yet.
2019 T@B 400 BL
2021 Toyota Sequoia 4WD
Some methodical sleuthing will be required to figure out exactly where the connection is broken.
(*However, the battery should still be ON when towing. In the event of a full trailer separation, the battery is what powers the emergency breakaway brakes!)
That won't tell you about the connection to the TV, but will let you know if they engage at all.
Tampa FL
My plan is to use a multi-meter to check the trailer's electrical connections and go from there. Long stretch of cold rainy weather here has kept me from this so far. Will go back over the many suggestions and report back early next week!
You might be able to take the 7pin tester apart and add a resistor from the ground pin to the electronic brake pin. This would add enough load. You would need to do the math on what resistor and wattage it needs to be.
2025 Toyota Tundra / Nashville, TN
If you know you have a good tester, then you could go to the dealer and see if your tester works with one of their known good TVs. It would be hard for them to poo-poo your tester at that point.
You could also ask someone with a known good brake controller to hook up to your Tab and see if the Tab brakes make noise when the brakes are applied. You can hear them if you are close to them.
