Soot Removal?
DougHDougH Member Posts: 1,110
I wanted to dress up the T@B a little before trade-in time, so I put on 20" rims and super low profile tires. I was originally just going to add regular chrome spinners since they were on sale at the tire and wheel shop I used. But since I already had a tee-off of the propane line for the barbeque, they convinced me to purchase a $1700 flame spinner system instead. They ran new lines through the axle to replace the EZ-lube centers, and overall the auto spark system works great, and I'm only going through half a tank of propane on a typical travel day.
A couple rangers have given me grief in burn ban areas, but my real problem is the wheel well and camper side appearance. They're picking up a lot of soot or smoke or something.  I've tried various solvents, but can't seem to remove the stuff.  Should I just paint over it? Any other suggestions?
  • ScottGScottG Administrator Posts: 5,644
    Nice! I had spinners like that one season, but every time I hit a cross wind my tires caught on fire and exploded. I'm thinking your low profile skins probably help to mitigate that problem.
    That soot was always an issue for me, too. I never found any easy way to clean it off, so finally just gave up. After all, every stain tells a story!  :-)
    April Fool’s!
    I was hoping to see more date sensitive postings this morning.  Something like a 2021 T@B 400 for sale for only $1000, that has to be sold because they discovered their partner snores.
    Just doesn't seem practical @DougH. I read on Instabook that the trending thing to do is switch your electric dryer out for propane (with a T off the barbeque line) to make it easier to do laundry when boondocking.
    2019 320 Boondock Edge
     - Sold Jan 2022
    OK, CrabTaB, but a propane torch connected to the tee can be used to speed dry clothes on a small line, saves bulk and weight, and hauling a dryer around...  B)
    edited April 2021
    OK, good April 1 ha, ha guys...
    Doug, saw right through this one, soot looks airbrushed in, nice try... ha, ha...
    On a serious note, tying into the thread title, I recently discovered you can remove a lot of stains, including glue residue left by command hooks, from the side of the TaB by using good ole WD40.  On dry hard bits, let it soak in a while, and the junk is supposed to wipe right off.  Got this from Sean, the service tech at our nüCamp dealer Vogel’s in Ukahia.  Going to give this a try and report back in a separate discussion....
    Doesn't weigh any more than the electric dryer @Denny16, probably less since their isn't the weight of all the copper motor windings. I let you know if I decide to go with the mod.
    Since boondocking is becoming more in vouge though it is important that we keep up with things and not be caught airing out dirty laundry while on the road.   ;)
     - Sold Jan 2022
    edited April 2021
    Nice CrabTaB, but you could eliminate all motors, and go with a Stirling engine, getting its heat from the propane burner to rotate the dryer drum, more weight saved...
    We do not air out our dirty laundry sir, just our clean ones...
