We have a 2021 320S Boondock with the built-in solar. It also has solar port on the battery tub to add an external solar panel, (I believe it’s an SAE connector?). Is there any thing special I need to do, other than plug it in? I’m assuming I will need a panel with a built-in controller, (like one of the zamp “regulated” models?). Do the built-in and external solar panels work together additively? Are there any settings I need to change on internal Victron controller to make it work? I read somewhere that the Victron solar controllers would throttle down charging from the built-in panel if another external panel was plugged into the battery box connector, and the only way to get an additive effect of the two panels is if they were both physically wired through the same controller, true or false? Thanks to anyone that might be able to shed some light on this topic for me.
2021 T@B 320 S Boondock
2021 Honda Passport Elite AWD
Meridian, Idaho
0 ·
Meridian, Idaho
Meridian, Idaho
SW Colorado
Meridian, Idaho
Meridian, Idaho
If you went with a different brand like a Renogy that uses MC4 adapters, you would need a simple MC4 to SAE adapter - no biggie. By now, Renogy may even have an SAE connector. I like Renogy and we use their products. They will hold your hand through your set up - great customer service. Nice to be able to talk to someone.
Sorry if this is redundant.
Thanks, Bob
You need to look at the wiring inside of the tub to see how and where the Zamp connector is wired. My guess is that there is not another controller and the Zamp connects directly to the battery. If that is the case, you will need to buy a suitcase model with its own controller or buy a separate controller. I chose the separate controller so I could mount it as closely as possible to the battery. I also wanted the Victron controller with Bluetooth capability. Can you provide a photo of the wiring inside the tub?
Photos too large and deleted. Please resize these and future photos before posting. https://tab-rv.vanillacommunity.com/discussion/47/what-size-should-my-posted-forum-photos-be#latest
@lkc001 - Sorry this topic is so confusing!
There is nothing wrong or magic about the wiring of the port. Correct wiring of a Zamp port at the battery (or any port) is positive to positive and negative to negative, just as it should be and you should check it to confirm that it has not been changed by the previous owner. The ports are not wired in reverse of how they should be wired as long as the red wire sits at the + battery terminal and the black wire sits at the - terminal.
To be clear, the ZAMP controller plug was designed to protect against shock by shielding (recessing) the positive pin and required an SAE port with an exposed male pin as positive. The problem comes in when you want to plug into the SAE port using a plug end with an exposed positive pin. It will not aline positive to positive and negative to negative correctly. As long as you maintain the correct wiring connections (positive to positive and negative to negative) it really is just a FIT ISSUE!
To get around the FIT ISSUE, some owners alter the wiring at the solar controller, some change the wiring at the battery and others use multiple adapters. In the end, to make it Plug-n-Play, you must have an SAE connector at the end of your controller cabling with a shielded (recessed) + pin and an exposed - pin.
I don't know what kind of panel/controllers you have, but if you end up using MC4 connectors (appears pretty commonly used), here is a picture of what you will need. These are available on Amazon.
Also, here is a picture of what the SAE ends of a Zamp controller cable look like. You can see how they aline with the solar port. (Thanks Verna!).
