We're still in the process of outfitting our recently acquired 320S BD, and haven't yet been anywhere with it. Along with generally checking things out, I've also been tracking both the charging of the stock solar system and the battery voltage as it sat in our driveway. While I expected to see some variation in the voltage level over the course of the day, I've been a bit surprised to see it drop down to 12.30v and even to 12.27v one day.
I have not had any of the 320's 12v devices or lights for more than few minutes, with only one exception. That exception was running the Alde on propane for few hours on one day, just to ensure that the system was working properly (it was).
What could be using enough current to drop the battery to ~65% of capacity?
Assuming that your battery cutoff switch is in the "on" position, there's always going to be some parasitic draw. If you have a conventional (not lithium) battery the string of 12.6v figures represents a 100% charged battery. Then it starts dropping only around day 11 or 12. Was the weather bad (preventing the solar from topping up the battery)? Was it on Day 11 that you ran the Alde?
Brad
Concord, NC
@CharlieRN. Do you by chance have an inverter on your system?
My advice is Stop Worrying About the little details & Go Camping
If you run out of electrical power than you will have a worthwhile data point.
Sunsets & Sunrises are still wonderful even without lights . . . .
I'm not so into smartphone apps and high-tech power management, but hoo-boy, don't get me going on plumbing or wiring! :-)
