2021 T@B 320S Cabinet Removal
vflowers
Member Posts: 4
I know there is a thread, and I've read it regarding the removal of the cabinets from the back. I attempted to remove mine and wanted to as much as possible retain the quality of the bottom shelf and doors in case I wanted to replace them at a later date. After removing all the screws, it seemed as though there was someway that the front of the shelf was affixed to speaker cabinet that I couldn't figure out. Seems almost like a tongue and grove and you might have to make a cut. Any help appreciated.
Pictures may help.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
I think it was member @Tommy who first did this and wrote about. He hasn't been posting on the forum for some time, but knowing who you are looking for will help your search efforts.2015 T@B Max S (320)
Tommy thread goes back to 2016 https://tab-rv.vanillacommunity.com/discussion/3216/mod-report-removed-the-head-banger-cabinets/p1
I think there are other threads, but not sure specific to 2021.
https://tab-rv.vanillacommunity.com/discussion/comment/161131#Comment_161131
https://tab-rv.vanillacommunity.com/discussion/5212/open-up-your-cabinet
https://tab-rv.vanillacommunity.com/discussion/370/what-a-t-b-u-looks-like-without-rear-cabinets
@vflowers ... We took the lower cabinets out of the back of our 320S. It was not easy. Could be wrong, but I believe they put them in before adding the outer shell. Some of the screws are very difficult to remove and there are places where it's glued to the walls. As stated, some pictures of what your up to would help. Good luck!
To be clear, it is the top cabinets I am wanting to remove.
- 919 Introductions
- 74 Teardrop Groups & Links
