I spend most of my full-timer time in the southwest. I find the rear window of the T@B400, since it is nearly horizontal, lets way too much light and heat into the cabin. Shortly after I purchased my T@B I fabricated felt-lined plastic covers to fit the front and rear window when they are exposed to direct sun and I am stationary. The covers work very well at keeping heat out. I mounted suction cup hooks at the four corners of the window to secure the covers in place. It is a pain to deploy the rear cover, the hooks at the top of the window are impossible to reach from outside so I have to attach the cover by opening the window and, from inside, reaching through the window and around outside. I just purchased some light blocking static-cling window film that can be applied to exterior surfaces. I installed it and look forward to heat protection when I am stationary as well as towing. The film was easy to install and is removable since there's no adhesive. I'll update this post later to report how it works. The film was about $40 on Amazon. Brand: WindowWhirl.
Southern California
Full-timer since 2019
It is a rolled sheet of thin, plastic, tinted film that comes in varying degrees of transparency. It works by static cling and you apply it like a phone screen protector. This should help reduce fading, glare and heat. Good idea for use out west.
Southern California
https://windowwhirl.com/pages/shop
Southern California
@xdr - It stays on your windows. I would recommend trimming the corners into a curve to avoid rolling up.
You thoroughly clean the window with soapy water and rinse. Apply the film and smooth out the air bubbles with a credit card or squeegee. Well worth a try!
Sharon - where did you buy the "U" channel for the corrugated plastic panel? I've looked everywhere without success. I believe this was another Dale Mod from a year or so ago.
Southern California
Southern California
San Diego, CA
www.airbossone.com
Southern California
San Diego, CA
www.airbossone.com
Southern California
Southern California
Here is the link for the roof shade:
https://www.amazon.com/Hasika-Waterproof-Resistant-Multifunction-Traveling/dp/B00ZKYSCOM/ref=pd_sbs_5?pd_rd_w=4cRGY&pf_rd_p=98101395-b70f-4a52-af63-8fac2c513e02&pf_rd_r=H0E53EZ39RN77EPVB4J2&pd_rd_r=9c1653c2-b135-4db1-82f3-7ac031b335cd&pd_rd_wg=abR37&pd_rd_i=B00ZKYSCOM&psc=1
It doesn't require any support for the 320. You simply use four bungee cords secured to the four trailer handles. Don't insert the "left to right" fiberglass pole that comes with the shade - it will mar the trailer trim.
@jimcenname - due to the up-down curve of the window, the corrugated plastic is not perfectly flat. It is flexible and can pop out at higher speeds. Hence the aluminum strips. Here is Dale’s original thread: https://tab-rv.vanillacommunity.com/discussion/4874/front-window-rock-protection/p1
@Tabaz - we have a second “roof shade” on the way for use as a visor with brief stops. I am thinking about getting some aluminet to secure over the top. That would really shade the top much better.
2017 Highlander Limited
Southern California
film web site: https://gilafilms.com/for-home/gila-heat-control-platinum-static-cling-window-film
Southern California
Southern California
