Fantastic Fan Upgrade vs. Maxx Fan Replacement
manyman297
We've only had our 2021 400 BD for less than a week and we're already tired of the loud Fantastic fan that is preinstalled. I keep going back and forth on if we should do the easy thing (fantastic fan "guts" upgrade that a lot of you do) or the hard thing (Maxx Fan replacement).
Aside from the ability to run the Maxx Fan in the rain, it appears the fans have the same basic feature set, correct? For those with the Maxx Fan, do you find yourself running the fan much when it's raining? I'd rather do it right the first time so I'm tapping the community to see what their thoughts are.
2021 400 BD
2020 Tacoma TRD Off-Road
I did the upgrade, because I already has a Maxx fan type cover/hood over the outside of the fan, which allows use in rain, etc. The upgrade was easy, and no roof access was required. If I did not already have the fan hood, I would have seriously considered changing out to a Maxx Fan replacement.
2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.0 -
I did the upgrade and added the aeroflo vent cover, which allows me to leave the vent open on the road and in the rain. I think the whole thing cost me about $60. I'm happy with it. I hate throwing away perfectly useful things.
manyman, if you decide to upgrade to a Maxx Fan, save your Fanastic Fan to use in the wash room when that fan fails. Several TaBers who made the switch, did this, or just replaced the washroom fan before it failed.
I upgraded to the Maxx fan with the cover that raises/lowers. I like the sleek design and needed low profile for trailer to fit in the garage. I run the fan almost 24/7 regardless of weather. With the Maxx, the lid can be closed and the fan will still operate similar to a ceiling fan-I love the airflow. I like running it at night on lowest setting, which is very quiet, windows in cracked mode to draw in air. I bought mine on sale at Camping World and paid for install, so while cost was several hundred dollars, well worth the upgrade for me.Debbie in Oregon
Sold 2023 Tab 400
Sold 2018 T@B 320S2 -
Just did the upgrade from FantasticFan to MaxxAir 4500 (10 speed with remote}, only took about 15 minutes to remove old fan, maybe an hour to install new fan. Only two wires, easy upgrade. You have to do it from the side, you can't get on the roof, it has 50# weight limit. The difference is amazing. Best price for 4500 fan was at CampingWorld.
That was my initial plan but our 400 came with this:Denny16 said:manyman, if you decide to upgrade to a Maxx Fan, save your Fanastic Fan to use in the wash room when that fan fails. Several TaBers who made the switch, did this, or just replaced the washroom fan before it failed.
https://www.rvupgradestore.com/MaxxAir-00-03810B-MaxxFan-Dome-Roof-Vent-With-LEDs-p/14-9982.htm?gclid=Cj0KCQjw2NyFBhDoARIsAMtHtZ6EvrKdzrurDe9Qaag7H1X-ONl4ZCXBCNR9rkDyxJsNjIdSTwB70L4aArjWEALw_wcB
Nice upgrade from the cheap fan they normally use but it also means a round, small opening that would need to be cut larger.
I'm leaning towards the Fantastic upgrade just for the ease of install. I like the idea of being able to turn the fan on in rainstorms but I'm not sure how often that would happen and if ventilation would be needed.2021 400 BD
2020 Tacoma TRD Off-Road0 -
I like the low profile look of this vs. adding a cover over the existing fan. Do you use it much in the rain?dsfdogs said:I upgraded to the Maxx fan with the cover that raises/lowers. I like the sleek design and needed low profile for trailer to fit in the garage. I run the fan almost 24/7 regardless of weather. With the Maxx, the lid can be closed and the fan will still operate similar to a ceiling fan-I love the airflow. I like running it at night on lowest setting, which is very quiet, windows in cracked mode to draw in air. I bought mine on sale at Camping World and paid for install, so while cost was several hundred dollars, well worth the upgrade for me.2021 400 BD
I've got a Maxx fan on my new camper... versus an added vent cover on my previous T@B. The T@B cover had downward facing vents in the back so I could leave the vent open all the time in any kind of rain.
In contrast the Maxx fan on the new unit is not a rain sensing or low profile vent cover. Just a pretty big vent permanent vent cover. But without the louvered rear cover. So the other day a squall line of rain and wind came in from that direction... and J ended up with a big puddle in the trailer.
So either get a rain sensing vent that auto-closes, or get a vent cover that has plastic on the rear facing side too.2021 Jeep Gladiator, 2021 tiny toy hauler, Austin TX
@manyman297 yes, I use the Maxxfan in the rain. I'm in Oregon, we get rain! I run it almost 24/7 in any weather. I may have gotten lucky with the original Fantastic Fan, but I ran it too in the rain and never had any issues with rain coming in. I got the Maxx for the 10 speeds, especially the lower speeds, the quiet fan/motor, the lower amperage, and lastly the cover.Debbie in Oregon
Sold 2023 Tab 400
Sold 2018 T@B 320S0 -
I have done both the FF upgrade on my 2015 with the FF vent cover and the Max Air upgrade (7500) on my T@b. They are similar, but love the low profile look of the Max Air fan. I also like that you can run the Max Air fan like a ceiling fan without opening a window or door.
@manyman297 I thought I had read somewhere on this forum that the MAXX cover blocks some of the solar panel on the 2021 T@B 400... you might want to verify.
Cheers,
2021 T@B 400 Boondock 'Valhalla'
2018 Jeep Grand Cherokee Trailhawk V6
veni, vidi, bibi capulus0 -
I read that as well but I wasn’t sure if it was referring to the 320 or 400. I’m now leaning toward the maxx fan...but having had installed a maxx fan in our previous pop up, I’m dreading the sealant removal.CJax said:@manyman297 I thought I had read somewhere on this forum that the MAXX cover blocks some of the solar panel on the 2021 T@B 400... you might want to verify.
Cheers,2021 400 BD
@Denny16 Does the fantastic fan upgrade include the fan motor and when installed does the constant " growling " of the motor go away? I have the cowl on top and the speed control upgrade so dont care about rain sensor lid. I just want it to be quiet!!!! Keeps me awake on anything but the slowest rotation. What a noisy fan to fit in the main part of the camper. The bathroom fan is much quieter.
@Tundra57 The Fanastic fan upgrade does not change or include the motor, it replaces the controls and fan circuits, inside bezel, everything except the top lid and motor. It also includes the lift bar (which you do not need to use, the original one works). At the three lower speeds, the fan is very quiet, and not noticeable when running. We do not hear any growling noise.
@Denny16 Then my motor must be bad then. Even before the pwm speed mod it was noisy like a growling noise at anything above slow speed.Maybe im just sensitive to that frequency. I put the three speed resistor fan switch on the bathroom fan and it works great, the only sound at any speed is the noise generated by the blades and air movement on the bathroom fan. Maybe ill buy a fan motor and run it to see if its quieter.0
Turndra57, you might be able to get a new motor under warranty?cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.0
Yes, the fan spinning up is louder than the motor.
Good luck…
I will be doing the FF upgrade kit plus cover... the question then becomes, which cover is "best"... the FF cover, the Maxx cover, the Camco cover, or other? Which has the best combination of functionality and ease of installation? Price differences matter less to me within reason, just want best airflow, least rain ingress, and minimal mod to T@B.
Cheers,C2021 T@B 400 Boondock 'Valhalla'
@Denny16 and @CJax The replacement dometic fan came. It seemed still noisy on the bench. The motor is deeper.It fitted easily. It is a lot quieter and shifts nore air at full speed than the old one. At the same speed where the old one was making noise this one is quiet. Its still noisy at higher speeds but that is covered by the air tush noise anyway.So my combination of the fantastic manual fan, the dc variable speed drive mod and the top cover I am happy with it finally. Its quiet for night use and can be fully open in the rain snow or wind.0
How did the cover attach? The Dometic ones either attach by removing screws in the roof or attach to the 4 loops. My FF is a clamp on model so neither of those will work.Marceline said:I did the upgrade and added the aeroflo vent cover, which allows me to leave the vent open on the road and in the rain. I think the whole thing cost me about $60. I'm happy with it. I hate throwing away perfectly useful things.2006 RAM 1500 4 door, 2016 T@B 320 MAX S
Tampa FL0 -
@Tampakayaker I have a camco aeroflo. It mounts by screwing rt angle brackets into the side of the short square "tube" outside of the fantastic fan which supports the hinge lid of the fantastic fan.Then the aeroflo goes over the top so the fantastic fan lid opens inside. The aeroflo has side vents so it cant rain in.There is an installation pdf you can look at to see what i mean. Had it 3 years no problems.
Thanks, I’ll pull it up later when I get to my pc with a bigger screenTundra57 said:@Tampakayaker I have a camco aeroflo. It mounts by screwing rt angle brackets into the side of the short square "tube" outside of the fantastic fan which supports the hinge lid of the fantastic fan.Then the aeroflo goes over the top so the fantastic fan lid opens inside. The aeroflo has side vents so it cant rain in.There is an installation pdf you can look at to see what i mean. Had it 3 years no problems.2006 RAM 1500 4 door, 2016 T@B 320 MAX S
Tampa FL0 -
Glad you got it sorted finally. Enjoy…Tundra57 said:@Tampakayaker I have a camco aeroflo. It mounts by screwing rt angle brackets into the side of the short square "tube" outside of the fantastic fan which supports the hinge lid of the fantastic fan.Then the aeroflo goes over the top so the fantastic fan lid opens inside. The aeroflo has side vents so it cant rain in.There is an installation pdf you can look at to see what i mean. Had it 3 years no problems.
MaxxFan remains on my wish list three years into my T@B life.
In first few months of ownership I did the PWM 10 Bucks Fan Speed Controller modification so can control speed.
Still want the MaXXFan for it's cool design and built in cover.'18 320 S, pitched axle, 3020HE; PNW based
Adventures: 59 Nights: 411 Towing Miles 50,3501 -
We had the fantastic fan with the separate hood cover for our T@g...when we upsized the Maxxair Fan was one of the upgrades we added to the trailer from NuCamp...love the sleek design of it and that we can run the fan while the hood vent is closed...hubby loves the remote!Former 2017 T@G Max XL
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada0 -
Has anyone replaced the stock ceiling fan and hatch cover with an upgrade. My stock one leaks, but not all the time. There have been times in heavy rain no leaks and sometimes light rain it leaks. I checked the caulking and it looks like it has a good seal. Not sure what the problem is.0
Check to see that the top cover is down all the way round when it is closed, and no gaps are apparent. Water can splash up to a gap,on the cover if it is not closing tight.
Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.0
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
