I have 2017 T@B 320. The electrical from my Towing vehicle check out with 7 pin TESTER and they are tested OK. However my T@B license plate, headlight and reverse light on the T@B are not working. I changed out all the light bulbs but still not working. I checked fuses inside the T@B and nothing blown. Can someone suggest me where to look next? I need all the lights to work before the next trip. Thanks
0 ·
If it were me, I would start at where the harness comes into the TAB from the 7 pin connector to see if the ground wire is connected to the frame or not. If so, make sure it is clean and tight. Lightly tug on the wire to make sure it isn't broken where the terminal is attached. If it is broken, it will stretch.
Brad
Concord, NC
First I would visually inspect the wiring connections inside the Junction Box to make sure nothing is loose or disconnected.
Next, in this box from Pin1 (as per the diagram) is the ground wire(s) and is installed on Terminal 7 in the J Box. It appears that this is a white wire.
You will need a test light and have the 7 pin connected to the TV.
Step 1 would be to connect the ground of your test light to Pin 1 in the J Box
Step 2 would be to touch the probe to Pin 3 with the headlamps on on the TV, Pin 3 is the tail light circuit for the TAB
The light should light up, if it doesn't there is an open circuit. Since you have tested the TV with a tester, I am going to say the issue is on the TAB.
From there you can turn on each turn signal and check the pins in the J Box that correspond to the left and right turn signals etc.
Brad
Concord, NC
My impression is that all lights are directly grounded back to the tow vehicle via the junction box and do not rely on any frame grounds to operate.
Assuming they were working at one point, there may just be a bad/loose connection that is associated with the camera installation. That's where I would be looking since you have power at the J-box. Maybe a ground wire connection is loose?
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePo4; Solar: Renogy 100Ah Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
I don't know if you or someone else installed the camera, but if it were me, I would go back and check any wire connections between the camera and the license plate light. Jiggle the wires while you and/or a helper are watching the light to see if it flickers on and off.
[QUESTION: You mentioned your "headlights" in your original post. What were you referring to? Also, is it just the license plate light not working, or are your tail lights and/or running/side marker lights also not working? Additionally, you mentioned the "reverse light." Do you actually have a reverse light on your T@B, or are you referring to your tow vehicle?]
https://tab-rv.vanillacommunity.com/discussion/comment/128424#Comment_128424
