Hello,
I'm new here and this is my first post.
I did a bit of searching here before posting. I did find some posts about WDH but non that discuss the specific situation with a Boondock package and more specifically the front rack that extends over the tongue of the trailer.
Has anyone been able to successfully mount a WDH on a Boondock TAB 320? Can you share your experience? Photos?
I'm assuming the problem is the same on a TAG or TAB400 Boondock,
Thank you in advance and sorry if this has been covered before.
2022 T@B 320S Boondock
2021 Toyota RAV4 TRD Off Road
Ottawa, Ontario, Canada
Instagram: new.t@bventure
0 ·
Brad
Concord, NC
This is from the Nucamp support page:
Do I need a Weight Distribution Hitch?
The answer to this question can be a little tricky. While we do not recommend a weight distribution hitch(WDH) we know that they can be very beneficial depending on your tow vehicle. We would recommend consulting with a dealer to get their opinion on whether or not you would benefit from a WDH. They have much more knowledge and experience with towing and matching campers to vehicles.
There are 2 main types of WDH, bolt-on or clamp-on. While either model should work fine, we would recommend using a bolt-on style WDH. Again, we would recommend consulting with a dealer to find out which WDH is best for your application.
There are a few numbers typically associated with ALL TV's.
GVWR - Gross Vehicle Weight Rating
GCVW(R) - Gross Combined Vehicle Weight (Rating)
Payload Capacity - Difference between GVWR and the actual weight of your TV based on options etc.
Tongue Weight - Maximum allowable weight on your hitch, tongue weight is typically 10% (or more) of Gross Trailer Weight.
In addition, on some of the smaller TV's there is a "frontal area" specification for trailers that can be towed.
My suggestion rather than worrying about a WDH is to determine if the TV you are planning to use actually has the proper ratings that would make it suitable. The tongue weight on a 320 is less than 200 pounds and if this is too much weight for the TV you plan to use, I would suggest reconsidering.
Yes, I am aware that there are all kinds of people using marginal TV's or TV's that are overloaded; it happens every day. But, if you are exceeding the ratings of your vehicle there are a few things that can happen.
1. IF you were involved n a crash, your insurance company may deny the claim due to overload condition
2. IF you experience a TV failure while under warranty, your warranty may be revoked
3. It is just plain unsafe to do so and can cause poor handling issues, especially during an emergency maneuver.
Now, you may never have an issue and for the rest of us we certainly hope you do not. Take this for what it is worth.
Lastly, an RV sales person is the last one I would ever trust about answering the question "can I pull this with my X?"
Brad
Concord, NC
My question is not about my TV capacity to tow but about the installation of a WDH as it pertains to the Boondock front rack.
If you have sufficient TV GVWR, Payload Capacity, and Tongue Weight capacity the only remaining reason that WDH comes into the conversation would be if the rear of the TV sags. WDH were introduced decades ago to overcome this problem by transferring part of that tongue weight back to the trailer. Think of a big family station wagon and a heavier travel trailer.
There are other options available to correct this sag if it is an issue. Somehow, I don't think it will be depending on what you plan on hauling on the boondock platform. I met some people last fall using a Lincoln Navigator and had a 400 BDL with the platform, they were loaded very heavily on the platform (generator on one side and a bunch of stuff on the other) and were not using a WDH. Tongue weight on a 400 BDL is between 400 and 500 pounds, or so I am told. All I know is that I can't lift it like I could our 2017 320-S we had previously.
Brad
Concord, NC
Again, I believe I've done my homework on this and I'm definitely ok.
I plan to buy a 2021 TAB 320S Boondock "soon" and I want to know if it's possible to add a WDH considering the front platform extends over the trailer frame. Does anyone have any experience to share?
Don't mean to speak for Brad or others here. But just because it's doable doesn't necessarily mean it's a good idea. Think that's the gist of the cautionary comments here.
What ever you decide, wishing you good luck and happy camping!
San Diego, CA
www.airbossone.com
Again, I'm looking for views about installation on a Boondock tongue due to the rack extension over the frame should I decide to go that route.
Just cautionary notes towards an informed decision.
And sorry I can't help with the underlying question. Fairly certain there are others on here you can.
Cheers!
San Diego, CA
www.airbossone.com
Has anyone installed a WDH with the Boondock front platform in place? I think @Maple_Geek wants to know about placement and any installment issues.
Hope that adds some color.
SW Montana USA
I'm particularly interested in the Fastway WDH install.
Hope it helps a little. Don't know how or if a 320 has different geometry.
SW Montana USA
I'm curious to see the WDH install from @swiftwave
Thanks to all other replies also.
