Hi, All;
We’ve just bought a lightly used 2018 400.
Planning an early September trip from Anacortes WA to Long Island NY, using the 400 as a mobile quarantine. TV is a 2021 Ram 1500.
Putting on new tires as a precaution; and will add a sway control. Or should it be a WD hitch with sway, like the lightest Equal-I-zer, rated up to 4000 lb/ 400lb?
Would appreciate your suggestions and cautions about making this trip with an unfamiliar rig, especially items to service and tools I might not think of.
2020 Tacoma TRD Off-Road
Your vehicle is well suited for towing the 400. You should not need any additional devices. Watch your speed.
Was the glycol ever changed? Have you inspected the hoses for bulging?
Check the seal above the front window:
Tools: https://tab-rv.vanillacommunity.com/discussion/4732/recommended-tool-and-spare-parts-list
Service: https://tab-rv.vanillacommunity.com/categories/service-bulletins-from-factory
Maintenance: https://tab-rv.vanillacommunity.com/discussion/6393/maintenance-notices
2017 Highlander Limited
I've driven my 2021 T@B400 at least 15K miles with a Honda Ridgeline, and I don't use any sway control add-ons, and the T@B is rock steady - even with lots of wind (think insane west Texas winds).
I'd highly recommend trying it without anything before deciding to add additional hardware you may not need.
I can not imagine the trailer being any more secure or stable than it is with nothing added. And with a Ram 1500 pulling it, I'd think it would only be less of an issue. The 400 is a small trailer for a full size pick up...
2013 Tundra TRD 5.7L
Massachusetts
Boston Northshore
SW Montana USA
Brad
Concord, NC
Unless you're a real road warrior, I'd recommend keeping it under 300mi per day. You'll likely average around 45mph (meals, fuel, road construction, two lane roads, etc), so that's just under 7 hours, which is a relatively long day towing. Plan the trip so you arrive at your next campsite around 200pm-300pm., if possible.
Your trip is approx. 3000mi one-way in mid-September. Assuming you're planning to take I-90 most of the way, what are you plans on the return leg? I-90 thru the northern tier states in mid-late October can be a bit dicey so check weather. Some great weather apps out there...they'll come in handy.
Do a search on here for fuse inventory and location for your make and model. Go the expense of buying a complete inventory of all types (and fuse puller) and keep them stored in the rig. Nothing like a $2.00 part going sideways to ruin a day (or worse yet, an evening).
Your round trip should involve at least one oil change in your TV. Easy to overlook.
I carry a large plastic enclosed tote that contains all my fluids for the TV (coolant, brake fluid, power steering fluid, engine oil, transmission fluid, windshield wash, etc.) as well as a high powered battery charger/jumper unit. Saved my bacon once already.
There are a lot of trip planning apps out there and they are incredibly helpful. That said, nothing like a good old fashion Rand McNally Atlas to peruse through over an evening cocktail, glass of wine, or beverage of choice.
Obvious things like proper sized lug wrench, jack and jack stands, cordless drill with socket for stabilizers and bits for various uses, Gorilla tape, bit driver set, small but comprehensive tool kit (needle-nose Vise-grips are a God send!), and of course....patience. I am not known for being a patient person by any means, but...I can say a recent 8500 mile 8 week trip taught me alot about patience.
Anacortes, WA is a beautiful corner of the world. Spent many days and nights at the marina en route to points north in Canada on the boat. A nice place to call home.
Oh, and...keep a journal. It helps relive your adventures as the years go by.
Safe travels and blue skies...
San Diego, CA
www.airbossone.com
mary
Time to keep track of our memories, adventures and challenges for just ourselves and a journal sounds like a way to do it.
