Two questions that I'm having trouble searching for answers to. I have factory solar on my 320S with the SmartSolar MPPT 75|10 controller. I purchased a Renogy 100W suitcase without a controller and plan to use a Victron controller in the tongue box next to the batteries. First question is, should I use another 75|10 or are there advantages to going bigger? Second, there's a Victron BlueSolar controller that a little cheaper. I thought they were all Bluetooth capable, but the description says, "Remotely control and monitor the extensive features of your BlueSolar MPPT charger by attaching a Bluetooth dongle ...". Am I right in assuming that it would be better to buy the SmartSolar version for using the Victron app to pair the two controllers? Thanks!
0 ·
If it were me, I would use the Bluetooth version so they can be networked. You can network up to 10 Victron Bluetooth controllers together, they will automatically assign the master if I remember correctly.
Brad
Concord, NC
The SmartSolar was the way I went. I believe when you add the Bluetooth dongle to the BlueSolar it becomes more expensive than the Smartsolar, plus you have two components to mount.
2019 320 Boondock Edge - Sold Jan 2022
2017 Highlander Limited Platinum
I ordered a "used, like new" Eclipse like yours from Amazon but they sent me the older model. Had to send it back.
One more thing came up during my research. I read that to charge two batteries more evenly I should connect all the positive leads to one battery and all the negative to the other. Then add parallel jumpers between the two positives and the two negatives.
Is this a good idea? I’m having a hard time seeing how this differs from having all the connections on the first battery and running parallel wires to the second. Can anyone explain if/how this works?
The first method your mention is the correct way to charge.
If you hook up everything to the first battery and just add jumpers to the second battery, the resistance (further distance to travel) in the circuit will have more of the electricity flowing in and out of the first battery. The first battery will go through deeper charge/discharge cycles and wear out quicker.
Having the positive and negative leads on opposite batteries in the bank will make the electrons flow more evenly between them since the circuit routes directly through both batteries.
If you have two 6V batteries, you'd want to combine them in series, which doubles the battery voltage, but the combined batteries amperage will be at the level of one battery. Series would require connecting the positive terminal of one battery to the negative terminal of the other battery. The other positive and negative terminals are where you attach all the loads.
The replacement SmartSolar MPPT 75|15 came today (sent back a BlueSolar non-Bluetooth purchased by mistake). I got the new battery and controller wired and it appears to be working. I say "appears" because I ran out of time and have not yet connected my solar suitcase. It's wired to the port, but I'll have to wait until the sun's up tomorrow to check that end of the system. Networking the two controllers went smoothly, but I'm not yet sure what to expect.
edit to add:
Found a link and video that says, “ Connect either a BMV battery monitor, a SmartShunt, or the new Smart Battery Sense, to a Solar Charger.” The Smart Battery Sense looks to be the way to go.
"Smart Battery Sense is a wireless battery voltage and temperature sensor for Victron MPPT Solar Chargers. With voltage and temperature sense in place, batteries will be better charged; improving charging-efficiency and prolonging battery life."
