Removing A/C
Endo
Endo Member Posts: 12
Was wondering if anyone has removed their A/C? I know it sounds funny but we live in Colorado and really don't need the A/C, we thought about taking it out because the space would be great for storage.
  • jkjenn
    jkjenn Member Posts: 6,421
    It's a good idea. Would you get a cover for that space? I would think you would want to stick a piece of insulation there.
  • Nomad
    Nomad Member Posts: 7,209
    Can't imagine it'b be too hard.
  • Endo
    I was thinking about a cover for the outside but haven't found one yet, and sealing in up good from the inside too.
  • jkjenn
    If you call Elsie in parts at Pleasant Valley, she can send you one. They don't cost a lot.
    @OutbackAZ were you the one who pulled your a/c out? Could it be removed permanently?
  • Nomad
    Ya but Jenn - Those vinyl snapon covers wouldn't be good if you're turning the space into a cabinet.
  • Photomom
    Photomom Member Posts: 2,217
    It occurs to me that it might be a good spot for a microwave. In 30+ years of tent camping in the Northeast, there has been ONE night when it was too warm for sleeping.
  • jkjenn
    In PA/OH the humidity gets you.
  • Endo
    Thanks Jenn!!
  • Photomom
    In any case the A/C will stay until we know what it's like to sleep in a camper.
  • Tabaz
    Tabaz Member Posts: 2,420
    Yes it was me who removed the A/C. Should be a searchable thread on this topic. Too small an opening for a microwave (mine is located on the pedestal). Weight savings of about 38 lbs. leaves a fairly unusable space for anything of consequence. Too high for drawers. So my A/C is back in situ waiting for a warm day.
  • jkjenn
    You could fit more clothes in there than those 3 back cabinets on an S model, I'd bet.
  • Endo
    We have a M@x S and thought it would be good space for blankets and jackets.
  • Tabaz
    Endo - find the previous thread. It's not a "pretty" opening. I suggest you live with your Tab for awhile and then revisit this issue.
  • ChanW
    ChanW Member Posts: 3,165
    It could be finished off, lined and some kind of trim boards on the front.
    I'd consider removing it completely if I knew I'd never want the AC. No more bumped head (there anyway).
    Might make it durn roomy in there!
  • Verna
    Verna Member Posts: 6,876
    While a storage cabinet would be nice, I think of resale. Here in the Midwest, you need A/C for the humidity. Last summer at Tearstock with temps in the mid to upper 90's every day, the A/C is a must!
  • Ratkity
    Ratkity Member Posts: 3,770
    Regarding the outside panel issue. Have you considered making it an accessible outside storage door area. Granted, it's a little high, but it would be able to be waterproofed and locked. It was just a thought.
    If you have an Outback and are short, you need to carry a step anyhow to reach the spare tire nut release on the yakima rack. I'm 5'6" and need a small step to reach the spare on the added yakima rack on my T@Bitha without the added few inches of the Outback axel. I also carry the adjustable step when I use the tent because the skirting covers the pull-out step. It's been very handy for lots of things and stores flat.
  • Tabaz
    edited October 2021
    Here is the link with photos.  Or search for "How to remove the air conditioner."
    http://tab-rv.vanillacommunity.com/discussion/2709/how-to-remove-the-air-conditioner/p1
  • susaninnh
    susaninnh Member Posts: 11
    Link to photos about removing a/c are not functioning . We have a U with the floor level a/c and would like to remove for more floor space as we travel with dogs.
    edited October 2021
    @susaninnh - I fixed the above link.  Tabaz’s A/C is in a 320.  It is mounted above the bench.  There is a thread around here showing removal of the floor level CoolCat that I will try to find.
    Here:  https://tab-rv.vanillacommunity.com/discussion/comment/142383#Comment_142383
