For the first time, I found myself in really cold weather - woke up to -4C (24F). I was toasty warm but there was a lot of condensation on the windows and by the door (on the ceiling and wall in the cubby by the door, on the floor, around the door). I had left the vent open through the night but obviously that wasn't enough. What do you do to avoid this? Use the dehumidifier on the Elwell? Stuff some padding in the door?
                2021 Tab320S Boondock, 2019 Subaru Outback 2.5
0 ·
Huntington LI
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
My version is here:
https://tab-rv.vanillacommunity.com/discussion/comment/140981/#Comment_140981
Or go to the top of that long thread for his original version, or other versions in the same thread.
Alde worked great.
Jeep Wrangler JLU
3.6L eTorque
3.25 inch hitch drop
Comes down to outside humidity expressed as dew point, inside temp and how much moisture we add by breathing / cooking. We'd never condense if we didn't add the moisture, as the air/moisture is always at the outside conditions or warmer inside the trailer. With no venting or people inside, the trailer can condense with a humid day and rapid temp drop.
managed by VE Smart Network
